Verifying services are running in NIOS (1500)
You are a NIOS Grid operator responsible for monitoring service health. Users report that some clients cannot obtain DHCP leases or resolve hostnames that should be served by Grid member ibns2.techblue.net.
  • 10 to 15 minutes
ops
  • Read-only access to Grid
Task 1: Verifying service status in GM
Verify DNS and DHCP service status for ibns2.techblue.net in Grid Manager.
Task 2: Verifying service status in syslog
Verify recent DNS and DHCP activity for ibns2.techblue.net using syslog..
Task 1 Solution: Verifying DNS and DHCP service status in Grid Manager
In this task, you confirm from the Grid Manager interface that both DNS and DHCP services on ibns2.techblue.net report a healthy Running status.
  2. Navigate to Grid → Grid Manager → Services
  3. Verify DNS and DHCP services are running for ibns2.techblue.net
Alternatively, you may find the same information in the web interface this way, one service at a time:
  2. Navigate to Data Management → DNS → Members
  3. Confirm that ibns2.techblue.net shows Running for DNS
  4. Navigate to Data Management → DHCP → Members
  5. Confirm that ibns2.techblue.net shows Running for DHCP
Task 2 Solution: Verifying service status in syslog
Even if the services show Running, you should confirm that they are actively processing requests. In this task, you use syslog filters to verify recent DNS and DHCP log messages from ibns2.techblue.net.
  2. Navigate to Administration → Logs → Syslog
  3. Select ibns2.techblue.net from the drop-down menu near the top of the screen
  4. Click Show Filter
  5. Apply filter criteria Server equals DNS
  6. Confirm that you see recent DNS log messages from ibns2.techblue.net.
  7. In the same filter, change to Server equals DHCP and click Apply again.
  8. Confirm that you see recent DHCP log messages from ibns2.techblue.net.
