Verifying NTP configuration in NIOS Grid (1501)
The security and compliance team has requested that you verify the NIOS Grid and all Grid Members are configured to synchronize time with the company time server, 10.35.22.20. Please verify the current NTP configuration on the Grid.
  • 15 to 20 minutes
ops
  • Read-only access to Grid
Task 1: Verifying NTP configuration in GM
Login to the GM web interface and verify the Grid NTP configuration is set to synchronize with the time server 10.35.22.20
Task 2: Verifying member NTP configurations
Use the GM web interface to verify the NTP configuration for each Grid Member (ibgm, ibgmc, ibns1, ibns2, and ibrep). Ensure every member is configured identically to use the same time synchronization source.
Task 1 Solution: Verifying service status in GM
Login to the GM web interface and verify the Grid NTP configuration is set to synchronize with the time server 10.35.22.20.
  2. Navigate to Grid → Grid Manager → Members
  3. From the Toolbar, click the NTP dropdown and choose NTP Grid Config.
  4. Verify that the GM is synchronizing with 10.35.22.20.
Task 2 Solution: Verifying member NTP configurations
The members, by default, synchronize their clocks with the GM unless specifically configured otherwise. We can double check this from the GUI and verify the NTP configuration for each Grid Member (ibgm, ibgmc, ibns1, ibns2, and ibrep).
  3. Choose a member (example shows ibns1.techblue.net) by checking the box to the left of the member name.
  4. From the Toolbar, click the NTP dropdown and choose NTP Member Config.
  5. Check the NTP Synchronization configuration
  6. Repeat for other members.
