Verifying NIOS Grid backup configuration (1502)
The systems team has requested that you verify all NIOS Grid configuration is being backed up on a regular schedule to the remote server 10.100.0.11. Please verify every Grid Member is backing up its configuration and data.
  • 15 to 20 minutes
ops
  • Grid Admin access
Task 1: Verifying Grid backup configuration
Login to the GM web interface and verify the Grid configuration and data are being regularly backed up to the remote server 10.100.0.11.
Task 2: Verifying member backup configurations
Login to the GM web interface and verify that each Grid Member is on the same backup schedule, sending backups to the same remote server 10.100.0.11.
Task 1 Solution: Verifying Grid backup configuration
Login to the GM web interface and examine the service status of the member ibns2.techblue.net visually.
  2. Navigate to Grid → Grid Manager
  3. From the Toolbar, choose Grid Backup → Schedule Backup
If backups have been configured to a remote server, the operation should show the backup destination and protocol used for file transfer. Here, backups have not been configured. We can double-check by switching between the different protocols available for file transfer out of NIOS and check whether the configuration is present for TFTP, FTP or SCP. Screenshots below show configuration for each of the 3 supported protocols:
  • TFTP
  • FTP
  • SCP
Task 2 Solution: Verifying member backup configurations
Members do not have the ability to back up their databases individually. The GM holds the Grid Database, which is comprised of all member databases and configurations. One NIOS Grid, one backup file.
