Creating NIOS Smart Folders (1505)
Your manager has asked you to train your team to quickly locate networks based on physical location and department assignment. Knowing that there are two Extensible Attributes (EA) Department and Building set up in the NIOS Grid, please create a global Smart Folder that your team members can use to quickly locate IPv4 and IPv6 networks based on Building and Department.
  • 10 to 15 minutes
morpheus
Requirement
  • Read-only access to Grid
  • Read-write access to Smart Folders (Admin access)
Task 1: Creating a Global Smart Folder
Login to the GM web interface, navigate to the Smart Folders tab, and create a Global Smart Folder that lists all IPv4 and IPv6 networks. Be sure to group the results first by Building and then by Department.
Task 1 Solution: Creating a Global Smart Folder
There are two types of Smart Folders: My Smart Folders and Global Smart Folders. In order for other users to access that Smart Folder you are about to create, you must make it a Global Smart Folder. My Smart Folders are only accessible to the creator.
  2. Navigate to Smart Folders → Global Smart Folders
  3. Click Create
  4. For Name, enter Networks by Building
    For Comment, enter Building-wise network list
  5. Click the Choose Filter dropdown and select Type
  6. Click the Choose One dropdown and select Network
  7. Click the Apply button
  8. Check the checkbox labeled Group Results, select Building from the Group By dropdown, and click the +
  9. Select Department from the second Group By dropdown
  10. Your Smart Folder should look like the following:
  11. Click the Save button
  12. You will now see your new Smart Folder in the list
