Using NIOS Status Dashboard (1506)
Your team would like to be able to put up a near real-time display of the DHCP service status on a screen. You know that both Grid Members ibns1 and ibns2 are running DHCP. Please create a Status Dashboard in NIOS that displays DHCP service and system information for both members.
  • 10 to 15 minutes
ops
  • Read-only access to Grid
  • Read-write access to Dashboard
Task 1: Creating a Status Dashboard and adding contents
Login to the GM web interface. Create a new Status Dashboard named DHCP Watcher. In the new dashboard, add the content DHCP Statistics and Member Status for both members ibns1 and ibns2. To receive near real-time updates be sure to enable auto-refresh. The result should have four (4) widgets displayed on the screen, clearly showing the DHCP service statistics (such as number of requests) and System Status (such as CPU and memory usage).
Task 1 Solution: Creating a Status Dashboard and adding contents
Login to the GM web interface and examine the service status of the member ibns2.techblue.net visually.
  2. Navigate to Dashboard → Status
  3. Click on the dropdown next to the gear icon and select Add Dashboard
  4. Name the Dashboard DHCP Watcher and click Save and Close
  5. A new blank Dashboard is created
  6. Click on the dropdown button next to the Dashboard name and choose Add Content
  7. From the content list, add Member Status and DHCP Statistics by dragging them into the Dashboard or by clicking the +
  8. The Widget will default to displaying GM information. Change the member by clicking on Select Member
  9. Choose ibns2.techblue.net from the list
  10. If the configure option is not available, click on the gear icon at the top right of the widget
  11. Set Auto Refresh Period to 60 seconds and check the box
  12. Repeat the steps for DHCP Statistics
  13. Add the same widgets again for ibns1.techblue.net
  14. The resulting Dashboard should look like the below image (numbers will vary)
