Using NIOS Global Smart Folders (1507)
Someone else on your team has created a Global Smart Folder named Networks by Building and Department. Please make use of this Global Smart Folder for yourself.
  • 5 to 10 minutes
ops
  • Read-only access to Grid
Task 1: Linking to a Global Smart Folder
Login to the GM web interface. Navigate to Smart Folders. Choose the Global Smart Folder and create a link. Expand the Smart Folders tab under Finder to view live results from this newly linked Global Smart Folder.
Task 1 Solution: Linking to a Global Smart Folder
Login to the GM web interface and link the Global Smart Folder Networks by Building and Department
  2. Navigate to Smart Folders → Global Smart Folders
  3. Select Networks by Building and Department
  4. Link the Smart Folder by clicking Create Link icon
  5. Networks by Building and Department is now available in the finder panel under Smart Folders
  6. After linking, Networks by Building and Department also becomes available under My Smart Folders
