Updating NIOS DHCP objects with Extensible Attributes (EA) (1508)
A new Extensible Attribute (EA) called Department has been added to the NIOS Grid. You are given the task to update some objects to fill in the value for this new field.
  • 20 to 30 minutes
ops
  • Read-write access to DHCP objects to be updated
Task 1: Updating DHCP ranges EA
Login to the GM web interface. Ensure the new column Department is visible for the network objects. Update networks with Department as listed in Table 1508-1 below.
You can update multiple objects at once
Table 1508-1
DHCP Ranges
Department
10.100.0.10 – 10.100.0.20
Engineering
10.100.0.30 – 10.100.0.50
Engineering
10.200.0.15 – 10.200.0.35
Finance
10.200.0.55 – 10.200.0.65
Finance
Task 2: Updating DHCP fixed-addresses EA
Login to the GM web interface. Locate and update the fixed-addresses with Department as listed in Table 1508-2 below.
You can use Global Search to search for the objects and update them
Table 1508-2
Fixed Address MAC
IP Address
Department
b8:49:19:da:6e:d8
172.31.2.78
Engineering
e7:8f:b1:f4:59:61
172.31.177.223
Finance
0f:23:d4:76:20:ed
172.31.82.37
Sales
Task 1 Solution: Updating DHCP ranges EA
Ranges and Fixed addresses are both child objects of Network. Check for parent objects of ranges 10.100.0.10-20 and 10.200.0.15-35
  2. Navigate to Data Management → DHCP → Networks.
  3. In the Go to field, enter 10.100.0, the system will automatically attempt to auto-complete the entry.
  4. Clicking on the first match 10.100.0.0 takes us to the parent network.
  5. Here we can see both the range objects together.
  6. Select them both by checking the box to the left and then click the Extensible Attributes button from the Toolbar to open the Multi-obect Extensible Attribute Editor window
  7. Click + to add Extensible Attribute values to all selected objects
  8. Select the Attribute Name, populate Value, and click Save
  9. Repeat the previous steps for 10.200.0. ranges
Task 2 Solution: Updating DHCP fixed-addresses EA
The same method can be used to find the Fixed Address objects and edit them as well. This may be tricky because these fixed addresses belong to different parent networks. However, since they share common octets and belong to the data type Fixed Address, we can use Global Search to find them
  2. Navigate to Global Search → Advanced
  3. Change search filter to Type equals IPv4 Fixed Address
  4. Provide search string 172.31.*.* and click Search
  5. Search results display all objects that match criteria
  6. Any search result can be edited by selecting the object and clicking Edit
  7. Within the object editor, click Extensible Attributes
  8. Click Add to fill in Extensible Attribute values
  9. Click Save and Close to save changes
  10. Repeat steps for other matched objects
