Exporting DHCP ranges data from NIOS (1510)
Your manager asked you to send her a list of all DHCP ranges configured on the NIOS Grid. Please use the CSV Job Manager function to generate this list.
  • 5 to 10 minutes
morpheus
  • Read-only access to Grid
  • Read-only access to DHCP ranges (objects to be exported)
Task 1: Exporting all DHCP ranges
While it is possible to export one DHCP range at a time in the GM, it is difficult to use the graphical interface to bulk-export this object. Instead, use the CSV Job Manager tool to export all DHCP Ranges quickly. Open the exported data (CSV format) and remove unneeded data if desired.
Task 1 Solution: Exporting all DHCP ranges
The CSV Job Manager can be used for this exercise
  2. Navigate to Grid → Grid Manager
  3. From the Toolbar click on CSV Job Manager
  4. Once the CSV Job Manager opens, switch to CSV Export
  5. In the CSV Export window, click + to add a New CSV Export job
  6. This opens the Global CSV Export Wizard, where you can choose what you want to export
  7. Change the separator if you want to (Comma is used by default)
  8. Scroll down the list of objects and check the box for IPv4 DHCP Ranges
  9. Click Export Data
  10. Read the message and click Yes to start the export operation
  11. CSV Global Export progress will show the export status
  12. Once the export finishes, the browser will prompt for the download location and filename for the exported file
