Creating DHCPv4 fixed addresses in NIOS (1512)
A support engineer has requested to always receive the same IP address, 172.31.100.17. She has provided her MAC address 2C-7A-E9-93-68-03. Please make the necessary configurations in NIOS for this support engineer. You should first search to see if the MAC address of the support engineer’s device already exists in the Grid, then create a DHCPv4 fixed address if needed.
  • 10 to 15 minutes
ops
  • Read-write access to DHCP fixed-address
Task 1: Searching for existing entries
Login to the GM web interface. Use global search to search for the MAC address 2C-7A-E9-93-68-03. While it is possible to have multiple fixed addresses with the same MAC address, this is a good practice to verify if there are older entries that need to be cleaned up before the current one is entered.
Task 2: Creating a DHCPv4 fixed address
Login to the GM web interface. The user did not specify which network but they have provided an IPv4 address. A search for the IPv4 address 172.31.100.17 will reveal which IPv4 network it is a part of. Navigate to the IPv4 network, and create a fixed address with the MAC address 2C-7A-E9-93-68-03 and IP address 172.31.100.17.
Task 1 Solution: Searching for existing entries
  2. Navigate to Global Search → Advanced
  3. Provide the MAC address as a search string then click Search for Type equals All
  4. Here we see no information, indicating that the MAC address is not present in NIOS database
Now we can create DHCP fixed address to complete our support engineer’s request that she needs her client system to receive the same IP address from DHCP server. In this scenario, a reservation would be a bad choice, because once a reservation is created, DHCP server will not be able to allocate that IP address to any client, which also includes the client system of our support engineer.
Task 2 Solution: Creating a DHCPv4 fixed address
  2. Navigate to Data Management → DHCP → Networks
  3. In the Go to field, type in 172.31.100.0 and click on the first match
  4. Open the network object 172.31.100.0/24 by clicking on Open (→)
  5. Here, we can see a DHCP Range object 172.31.100.5-172.31.100.35
  6. We can create the Fixed Address within this range. Click + from the dropdown and choose Fixed Address
  7. Click Next for the first step of Add IPv4 Fixed Address Wizard (no templates available in lab)
  8. In step 2, provide the IP address 172.31.100.17. In the Assign IP Address by field, choose MAC Address and provide 2C:7A:E9:93:68:03
  9. Click Save and Close to finish creating the Fixed Address object
