Creating DHCPv4 failover ranges in NIOS (1514)
The network team has provisioned a new IPv4 subnet and has requested that a new range of 20 addresses in the subnet to be handed out dynamically. Please create the appropriate objects in NIOS.
  • 15 to 20 minutes
ops
  • Read-only access to DHCP members and failover associations
  • Read-write access to DHCP ranges
Task 1: Creating a DHCPv4 failover range
Login to the GM web interface and create the DHCPv4 range 172.31.110.17 – 172.31.110.36, enough for 20 IP addresses.
How do you know that this requires DHCP failover? And how do you find out which failover associations to use? Look at the network configuration to see which members are serving the network, then compare that to the DHCP Failover Associations to find out which one you should use for the range.
Task 2: Monitoring DHCPv4 failover association status
In the GM web interface, navigate to the DHCPv4 failover association and monitor its status change. Verify the status is Running OK.
Task 1 Solution: Creating a DHCPv4 failover range
A Failover Range is a range that is served by an IPv4 DHCP Failover association and involves two DHCP servers. Creating the failover range object is like creating a regular range, except the failover range will be served by a Failover Association instead of individual DHCP servers. An important consideration while creating Failover ranges is to provide some buffer space for extra IP Addresses. This should be done to ensure service continuity in case one of the Failover peers fails and the service is restricted to just one server.
  2. Navigate to Data Management → DHCP → Networks
  3. In the Go to field, type in 172.31.110.0 and click on the first match
  4. Open the network object 172.31.110.0/24 by clicking on Open (→)
  5. Once inside 172.31.110.0/24, click + from the dropdown and choose Range
  6. Click Next for the first step of Add IPv4 Range Wizard (no templates available in lab)
  7. In step 2 provide Start and End IP addresses along with a name for the range and click Next. Here we are provisioning the range with an extra buffer of 30%. Instead of 20 IP Addresses, we are creating a range of 26.
  8. In Step 3, if you choose Grid Member, you will see that there are two members assigned to the parent network
  9. This gives us a hint as to which failover association we should assign this range to. Cancel the operation to check the failover configuration
  10. To verify, we can check for existing DHCP Failover configuration
  11. Navigate to Data Management → DHCP → Members → IPv4 DHCP Failover Associations
  12. In the lab, there is only one Failover association, which we can Edit to make sure that it was created with ibsn1.techblue.net and ibns2.techblue.net
  13. In the Object Editor window, we can see that ibns1.techblue.net is the DHCP Failover Primary and ibns2.techblue.net is the DHCP Failover Secondary in this D1-D2 failover association
  14. We can now go back to the range object and assign it to this Failover Association to complete our range creation. Repeat steps 1 through 7.
  15. In step 3 of Add IPv4 Range Wizard, choose IPv4 DHCP Failover Association and click Select Association
  16. Since there is only one Failover Association in the lab (D1-D2 failover), it will be selected by default
  17. Finish by clicking Save and Close.
  18. Restart service when prompted.
  19. Once finished, we can see our failover range in the network object 172.31.110.0/24.
Task 2 Solution: Monitoring DHCPv4 failover association status
Validate that the DHCP Failover Association comes up, and is Running OK.
  1. From the Data Management → DHCP → Members → IPv4 DHCP Failover Associations tab
  2. Validate the Status is Running OK. This could take a minute or two. You may also use the refresh icon
    in the GM interface to refresh the screen.
