Identifying MAC Addresses from DHCP Leases and Syslog in NIOS (1516)
A network troubleshooting task requires identifying the MAC address of a client that received a specific IP address via DHCP. However, the environment uses a DHCP failover configuration, and it's crucial to also determine which DHCP server issued the lease. You'll use the Grid Manager UI to investigate the DHCP lease table and analyze syslog logs to pinpoint the DHCP server involved in the lease assignment.
  • 15 to 20 minutes
ops
Requirement
  • Read-only access to Grid
Course References
  • 1013: NIOS DHCP Failover Overview
Task 1: Requesting a DHCP Address
Log in to the testing-windows VM and use the necessary commands to release any existing IP address, if assigned. Then, request a new DHCP address for the Windows client using ipconfig /renew and verify the assigned IP address using the ipconfig command.
Task 2: Tracing DHCP Lease Source and Client MAC
Log in to the Grid Manager UI and navigate to the DHCP lease table. Use the IP address obtained in Task 1 to filter the table. In a DHCP failover environment, there may be two lease entries for the same IP. Use the lease details for each entry to determine the MAC address of the client and the DHCP server that issued the lease.
Task 3: Confirming Lease Assignment via DHCP Logs
From the Grid Manager UI, access the syslog logs for both failover members (ibns1.techblue.net and ibns2.techblue.net). Filter the DHCP logs using the IP address obtained in Task 1. Identify which server sent the DHCPACK message to confirm which DHCP server completed the lease assignment.
Task 1 Solution: Requesting a DHCP Address
To request a new DHCP address, follow these steps:
  1. Log in to the testing-windows VM using the default credentials:
    • Username: training
    • Password: infoblox
  2. Click on the Tools folder on the desktop.
  3. Inside the folder, find the file interface-dhcp.bat.
  4. Right-click on the file and select 'Run as administrator'.
  5. Open Command Prompt
    • Click on the Start menu.
    • Type cmd in the search bar.
    • Select Command Prompt from the search results to open it.
  6. Use the command ipconfig /release and press ENTER in the Command Prompt.
  7. This command releases the currently assigned IP address, returning the client to a 169.254.x.x address.
  8. Use the command ipconfig /renew and press ENTER in the Command Prompt.
  9. This command requests a new IP address from the DHCP server.
  10. After the process is complete, use the command ipconfig again to verify that the client has received a new IP address.
  11. Note the assigned IP address for use in the next task.
Note: The IP address shown in the screenshot may differ from the IP address the DHCP server provides to the Windows client during this lab.
Task 2 Solution: Tracing DHCP Lease Source and Client MAC
To identify the MAC address and lease source, start by accessing the DHCP lease table:
  1. Log in to the Grid Manager UI.
  2. Navigate to Data Management → DHCP → Leases.
  3. Click Show Filter at the top of the table to enable filtering options:
    1. From the Choose Filter drop-down menu, select IP Address.
    2. From the Choose Operator drop-down menu, select equals.
    3. In the text field, enter the IP address obtained in Task 1.
    4. Click Apply to refine the results.
    5. In a DHCP failover setup, two entries for the same IP may appear.
    6. The MAC address is visible directly in the lease list.
  4. Select an entry from the filtered list and click Lease Details.
  5. In the Lease Details window, look at the "Served By" field.
    • This shows which DHCP server issued the lease to the client.
Task 3 Solution: Determine Lease Source from DHCP Logs
To confirm which DHCP server issued the lease, review the syslog entries for DHCPACK messages:
  2. Navigate to Administration → Logs → Syslog.
  3. From the Member drop-down list, select ibns2.techblue.net.
  4. Click Show Filter, then:
    1. In the first row of the filter section:
      • From the Choose Filter drop-down menu, select Server.
      • From the Choose Operator drop-down menu, select equals.
      • Select DHCP from the third drop-down menu.
    2. Add a second filter by clicking the + icon on the right.
      • In the new filter row, from the Choose Filter drop-down menu, select Message.
      • From the Choose Operator drop-down menu, select contains.
      • In the text field, enter the IP address obtained in Task 1.
    3. Click Apply to activate the filters and display only the relevant Syslog entries.
  5. Review the filtered Syslog entries:
    • Look for log messages related to the DHCP lease process. Check if there is an entry where the server acknowledged an IP address to the client.
  6. Repeat steps 3 to 5 for ibns1.techblue.net as well.
  7. Determine which member completed the lease assignment by finding which one logged the DHCPACK message.
    • The member logging the DHCPACK entry is the server that issued the lease.
