Restoring a DNS entry in NIOS (1524)
The Host record server1.techblue.net with the IP address 10.200.0.65 was deleted by mistake. Please restore it from the recycle bin and verify it has been recovered.
  • 10 to 20 minutes
ops
  • Read-write access to DNS records
  • Access to command-line tool such as dig
Task 1: Searching for the entry
Login to the GM web interface. Search the Recycle Bin to look for the Host entry for server1.techblue.net with the address 10.200.0.65.
Task 2: Restoring the entry
Restore the Host record for the name server1.techblue.net with the IPv4 address 10.200.0.65.
Task 3: Verifying object restored in GM
Navigate the user interface to verify the Host record is back and in the correct zone.
Task 1 Solution: Searching for the entry
Ranges and Fixed addresses are both child objects of Network objects. Check for parent objects of ranges 10.100.0.10-20 and 10.200.0.15-35
  2. Navigate to Global Search → Advanced. Enter server1.techblue.net as the search string then click Search for Type equals All DNS Records
  3. The Advanced Search returns no results,  as expected
We can double-check by searching inside the zone as well
  1. Navigate to Data Management → DNS → Zones
  2. Click on the zone name techblue.net  to enter the zone
  3. Inside the zone, switch to Records tab and use the Go to field to search for server1
  4. Click Go
  5. The message tells us there are No matching records found.
Since the record was deleted by mistake, it is most likely still in the Recycle Bin.
  2. Expand the Finder panel (If not already expanded)
  3. Expand the Recycle Bin by clicking +
  4. The deleted object is found within Recycle Bin
Task 2 Solution: Restoring the entry
Objects in the Recycle Bin can be easily restored with the help of the Restore button next to Object Names in the Recycle Bin.
  1. Hovering the mouse pointer on the deleted object name shows the Restore function
  2. Click Restore to restore the object
Task 3 Solution: Verifying object restored in GM
Once the Restore operation has completed, we can search for the object in Global Search to verify that it has been restored
  3. The results show that there is now a Host Record with the name server1.techblue.net and it has the IP Address 10.200.0.65.
The same can be verified from within the techblue.net zone as well
  4. Clicking on the first match in the Go to shows server1
