Researching Object Deletion History in NIOS (1525)
A user has reported that their device is unable to obtain an IP address, preventing network access. The user states that the device was previously assigned 172.31.101.23 as a fixed address and was functioning correctly earlier.
Your task is to investigate what happened to the fixed address by analyzing the Audit Log in NIOS and determine its current status. Based on your findings, take the required steps to resolve the issue.
  • 15 to 20 minutes
morpheus
Requirement
  • Read-write access to DHCP Objects
Task 1: Investigating the Missing Fixed Address
Log in to the Grid Manager UI and search for the fixed address 172.31.101.23 to confirm that it is no longer present in the system.
Task 2: Reviewing Audit Activity
Use the Audit Log in the Grid Manager UI to investigate whether any recent administrative actions may have affected the fixed address 172.31.101.23.
Task 3: Exploring Recovery Options
If your investigation in the previous task suggests that the object was removed, explore the available object recovery options in Grid Manager. Check whether the fixed address for 172.31.101.23 can be restored.
Task 1 Solution: Investigating the Missing Fixed Address
To check for the fixed address in NIOS:
  1. Login to Grid Manager web interface
  2. Navigate to Global Search → Advanced and provide 172.31.101.23 as a search string, then click Search for Type equals All
  3. The search results should not display any matching entries, confirming that the fixed address is missing.
Task 2 Solution: Reviewing Audit Activity
To investigate recent changes related to the Fixed address 172.31.101.23:
  1. Navigate to Administration → Logs → Audit Log.
  2. Click Show Filter at the top of the page.
  3. In the first row of the filter section:
    • From the Choose Filter drop-down menu, select Object Name.
    • From the Choose Operator drop-down menu, select equals.
    • In the text field, enter 172.31.101.23.
  4. Click Apply to filter the results.
  5. Review the filtered entries to identify if a deletion event occurred and note the timestamp and user responsible for the deletion.
  6. Based on the log details, we can conclude that the user Neo deleted the fixed address 172.31.101.23.
Task 3 Solution: Exploring Recovery Options
To determine whether the missing object can be restored:
  1. Navigate to Dashboards
  2. Expand the Finder panel (If not already expanded)
  3. Expand the Recycle Bin by clicking +
  4. Look for the deleted fixed address 172.31.101.23 in the list.
  5. If found, hover over the deleted object’s name to reveal the Restore function.
  6. Click Restore to reinstate the fixed address.
  7. When prompted, restart the service to apply the changes.
  8. After restoring, navigate to Data Management → DHCP → Networks → Networks → 172.31.101.0/24.
  9. You should now see an entry for the restored fixed address 172.31.101.23 in the list.
