Managing Resource Records Using DNS Views in NIOS (1529)
You are a DNS administrator responsible for maintaining split‑horizon DNS for your organization. Your Grid uses two DNS views: VPN for internal users connected through the corporate VPN, and External for clients accessing services from public networks. Your application team has requested an update to the host record ftp.techblue.net so that internal (VPN) clients receive the IP address 10.100.0.99, while external users receive 128.171.133.99. Your task is to update both views to ensure consistent resolution for all users.
  • 10 to 15 minutes
  • Read-write access to DNS records
  • Read-only access to IPAM or network data
Task 1: Verifying DNS resolution before making changes
Before modifying any records, verify how ftp.techblue.net currently resolves for both VPN-connected clients and external clients. Confirm that the hostname returns different answers depending on the DNS view in use, and note the differences so you can validate your updates later.
You may use the VMs testing-linux or testing-windows as clients connected over VPN. You may use the VM jump-desktop to simulate external clients (External).
Task 2: Update the record in the VPN view
Navigate to the VPN view, locate the record for ftp.techblue.net, and change its IP address to 10.100.0.99.
Task 3: Update the record in the External view
Navigate to the External view, locate the record for ftp.techblue.net, and change its IP address to 128.171.133.99.
Task 4: Verifying DNS resolution after making changes
Repeat the lookups from Task 1 to verify the new DNS resolution after making changes.
Instead of navigating to each view and zone, use the Global Search feature to perform the same updates.
DNS views allow different clients to receive different DNS responses based on source IP or network blocks. In this lab, separate views ensure internal VPN users receive internal service addresses while external users receive publicly reachable addresses.
Task 1 Solution: Verifying DNS resolution before making changes
Before you change any DNS records, confirm how ftp.techblue.net currently resolves in each DNS view. This gives you a clear baseline for comparison after you make updates.
Verifying from testing-windows
  1. Switch to the VM testing-windows and log in.
  2. Navigate to the Tools folder on the desktop. Right-click on the file interface-dhcp.bat and select 'Run as administrator'. This connects the virtual machine to the network using DHCP.
  3. Launch a command prompt by clicking on the icon in the systems tray.
  4. Use the nslookup command to verify DNS names. The example below performs two lookups, one for the forward-mapping name (ftp.techblue.net) and one for the reverse-mapping (10.100.0.22).
    C:\Users\training>nslookup ftp.techblue.net.
    Server:  ibns1.techblue.net
    Address:  10.100.0.105
    Address:  10.100.0.22
    C:\Users\training>nslookup 10.100.0.22
    C:\Users\training>
Verifying from jump-desktop
  1. Switch to the VM jump-desktop and log in.
  2. Launch a Terminal Emulator by clicking on the icon in the systems tray.
  3. Use the dig command to verify DNS lookup behavior. The example below shows how to verify both the forward-mapping (ftp.techblue.net) and the reverse-mapping (128.171.133.22).
    $ dig @10.100.0.105 ftp.techblue.net. +short
    128.171.133.22
    $ dig @10.100.0.105 -x 128.171.133.22 +short
    ftp.techblue.net.
Task 2 Solution: Update the record in the VPN view
  1. In Grid Manager, go to Data Management → DNS → Zones.
  2. Click the VPN view from the list of views.
  3. Click the authoritative zone techblue.net.
  4. Scroll down to the record for ftp, highlight it, and click Edit.
  5. Update its IP address to 10.100.0.99. Click Save & Close.
Task 3 Solution: Update the record in the External view
  1. In the Grid Manager, go to Data Management → DNS → Zones.
  2. Because there are views configured, you will see the views External and VPN listed. If you see a list of zones instead, it means you are already inside one of the DNS views. Click the link DNS Home above the view name (beneath the Zones tab) to return to a list of all views.
  3. Click on the External view.
  4. Click on the authoritative zone techblue.net.
  5. Scroll down to the record for ftp, highlight it, and click Edit.
  6. Update its IP address to 128.171.133.99. Click Save & Close.
  2. Launch a command prompt by clicking on the icon in the systems tray.
  3. Use the nslookup command to verify DNS lookup behavior. We look up the forward-mapping name and the IP address returned to check the reverse-mapping.
    Address:  10.100.0.99
    C:\Users\training>nslookup 10.100.0.99
    C:\Users\training>
  3. Use the dig command to verify DNS lookup behavior. Again, we verify both the forward and reverse mappings.
    128.171.133.99
    $ dig @10.100.0.105 -x 128.171.133.99 +short
    ftp.techblue.net.
A faster way to update records is to search for them using the Global Search feature and edit them in-line.
  1. In the Grid Manager, click the Search icon near the upper-right corner.
  2. This launches the Search dialog.
  3. Perform a basic search for DNS Name contains ftp.techblue.net. Click Search.
  4. Select the search results one entry at a time and Edit.
