Obtaining a DHCP Address (1532)
In this lab, you will work with a Windows client that currently has no DHCP lease. Your task is to manually obtain a DHCP lease for the client, providing it with a valid IP address from the DHCP server. This exercise will demonstrate using ipconfig commands to release and renew DHCP leases on a Windows system.
  • 15 to 20 minutes
Log in to the VM testing-windows to complete the tasks below:
Task 1: Initial Client Status Check
Verify the current status of the Windows client’s IP settings using the ipconfig command.
Task 2: Request a DHCP Address
Use the ipconfig /renew command to obtain a new DHCP address for the Windows client. Then, use the ipconfig command to confirm the new IP address.
Task 3: Release the DHCP Address
Use the ipconfig /release command to release the DHCP address currently assigned to the Windows client. Then, use the ipconfig command to verify that the IP address has been released.
Task 1 Solution: Initial Client Status Check
  1. Log in to the VM testing-windows
  2. Open Command Prompt
    • Open the Command Prompt by pressing Win + R, typing cmd, and pressing Enter.
  3. Verify the Windows Client's Current IP Address
    • In the Command Prompt, type ipconfig and press the ENTER key.
    • Review the output for the current network configuration.
  4. Expected Output
    • The output should display the current IP address. If the address is in the range 169.254.x.x, it indicates that the client does not have a DHCP lease.
Note: If an IP address is already assigned, run the following command to release the current IP configuration and ensure a fresh start: ipconfig /release
This will release the existing DHCP lease and allow you to obtain a new one in subsequent tasks.
Task 2 Solution: Request a DHCP Address
To request a new DHCP address:
  1. Use the command ipconfig /renew and press ENTER in the Command Prompt.
  2. This command requests a new IP address from the DHCP server.
  3. After the process is complete, use the command ipconfig again to verify that the client has received a new IP address.
Note: The IP address shown in the screenshot may differ from the IP address that the DHCP server provides to the Windows client during this lab.
Task 3 Solution: Release the DHCP Address
To release the DHCP address:
  1. Use the command ipconfig /release and press ENTER in the Command Prompt.
  2. This command releases the currently assigned IP address, returning the client to a 169.254.x.x address.
  3. Allow a minute for the IP address release process to complete and the network settings to update.
  4. To confirm that the IP address has been released, use the command ipconfig again.
