Recognizing DNSSEC-signed domains (1601)
Your organization has recently adopted DNSSEC, a valuable security measure that aligns with the latest recommendations for DNS security. As part of your responsibilities, you have been assigned the task of testing the resolution of your organization's DNSSEC-enabled zones, ensuring they can be accessed by the public while being properly signed.
To refresh your DNSSEC knowledge, you decided to validate a selection of public domains. These domains include some that are DNSSEC signed and others that are not.
  • 15 to 20 Minutes
Course References
  • 0301: Information Security Fundamentals
  • 1204: DNSSEC Fundamentals
Task 1: Recognize Signed Domains
In this task, we determine whether or not a particular domain name has been signed by DNSSEC, through querying for the SOA record of the domain and requesting additional DNSSEC information manually.
  1. Using the name server 8.8.8.8, determine which of the following domain names have been signed
    Domain Name
    Status
    www.fbi.gov
    www.yahoo.com
    www.infoblox.com
    www.ietf.org
    www.hawaii.edu
    www.dnssec-failed.org
  2. Which, if any, of the secure domains is bogus?
  1. Using dig with the name server 8.8.8.8, we determined that
    Domain Name
    Status
    Reason
    www.fbi.gov
    secure
    DNSSEC is implemented properly
    www.yahoo.com
    insecure
    DNSSEC is not implemented at all
    www.infoblox.com
    insecure
    DNSSEC is enabled on infoblox.com but not it's alias
    www.ietf.org
    secure
    www.hawaii.edu
    insecure
    bogus
    We cannot be sure just by doing this step
    You can follow the following syntax to validate each of the entries in the table:
    dig @8.8.8.8 [domain-name] SOA +dnssec +multi
  2. www.dnssec-failed.org is bogus and we can validate that by the SERVFAIL error response message.
