Changing NIOS Grid session timeout (2500)
There has been a recent security policy change, and you are informed that users are allowed to stay logged in to devices for up to 15 minutes (900 seconds). Please update the current NIOS Grid session timeout to match this new policy change.
  • 5 to 10 minutes
  • Administrative access to the NIOS Grid
Task 1: Changing the Grid session timeout
Login to the GM web interface and verify what the current session timeout value. Update it, if necessary, to match the new policy requirement of 15 minutes (900 seconds).
Task 1 Solution: Changing the Grid session timeout
Session timeout value is a Grid Property. To edit the existing timeout value:
  2. Navigate to Grid → Grid Manager.
  3. Select Grid Properties from the Toolbar on the right side of the window.
  4. Select the section for Security on the left side of the Grid Properties Editor window.
  5. Change the Session Timeout (s) value to 900 (900 seconds = 15 minutes)
  6. Click Save & Close
  7. Review the warning text, and click the Yes button to continue
