Configuring Syslog settings in NIOS (2503)
Your security team wants to make sure that all log messages from the Grid are being sent to the central log server for auditing and archiving purposes. Please make the necessary configuration changes.
  • 15 to 20 minutes
Task 1: Configuring external syslog settings
Login to the GM interface and make the necessary changes to send syslog and audit log messages to the external log server support-server) located at 10.35.22.20.
Task 2: Verifying on external syslog server
Login to the jump-desktop and use the Elasticsearch tool to verify syslog messages from the Grid are showing up.
The easiest way to generate some log messages is to log out of the GM, and log back in. These actions will trigger new Audit logs.
Task 1 Solution: Configuring external syslog settings
Configure the Grid to send syslog messages by UDP to your support-server: 10.35.22.20.
  1. Login to NIOS GM web interface, navigate to Grid → Grid Manager.
  2. From the Toolbar on the right side of the window, select Grid Properties.
  3. The Grid Properties Editor dialog window appears. Select the Monitoring tab on the left.
  4. Place a check mark in the box for Log to External Syslog Servers.
  5. In the section EXTERNAL SYSLOG SERVERS, click the Add (+) button to add a server.
    1. For Address, enter 10.35.22.20
    2. For Transport, set to UDP
    3. Leave all other settings at their default values
    4. Click Add to add this External syslog server.
  6. Scroll down further, place a check mark in the box for Copy Audit Log Message to Syslog
  7. Click Save & Close
  8. Restart Services when prompted
Task 2 Solution: Verifying logs on the external syslog server
Use Elasticsearch on the jump Desktop to verify that the Grid is sending Syslog and audit log messages
  1. Open Elasticsearch by clicking on the Infoblox logo/start menu at the bottom left corner of your Linux Desktop
  2. Choose Elasticsearch from the list
  3. Elasticsearch opens in a web browser window
  4. Login with username: training and password infoblox
  5. Skip adding integrations and click Explore on my own
  6. Open the menu by clicking the three lines below elastic from the top left of the screen
  7. Select Discover under Analytics
  8. In Discover, click the folder icon in the top-right corner and select Default.
  9. To find entries logged by the GM, type in log.source.address:10.100.0.100*  in the search box
  10. Entries sent from the Infoblox GM appear under the Message heading
  11. Your listing of events will differ from the example shown here
  12. Close the browser tab to exit Elasticsearch
