Creating extensible attributes (EA) in NIOS (2508)
The network team has decided to tag infrastructure and client devices according to the departments they belong to. This information will be mandatory for all new networks created, or when existing networks are updated. Please create the extensible attribute(s) that can be used to track this information in NIOS IPAM, making sure that this is only required for IPv4 and IPv6 Network objects.
  • 10 to 15 minutes
Task 1: Creating an extensible attribute
Create an extensible attribute named Department. This EA should allow users to select the correct department from a drop-down list. This list should contain:
  • Engineering
  • IT
  • Sales
  • Training
Task 1: Create an extensible attribute
  1. Navigate to Administration→Extensible Attributes
  2. Click the Add button
  3. For Name, enter Department
  4. For Type, select List
  5. To add the values, click the Add button and enter the first department name in the Value
    field
  6. Repeat previous step, entering the values for remaining departments.
  7. Click Next to proceed to Step 2 of the Add Extensible Attribute Wizard.
  8. In the section Default Value, click the radio button Required.
  9. Under the heading Restrict to Specific Object Types, click Add.
  10. Click the Name field, the object list opens. Scroll to locate IPv4 Network.
  11. With IPv4 Network in the Object Type list, click Add again.
  12. Click the Name field, the object list opens. Scroll to locate IPv6 Network.
  13. When complete, verify that your table contains both entries for IPv4 Network and IPv6 Network
  14. Click Save & Close
