Generating support bundles in NIOS (2509)
While working with Infoblox support, you are instructed by one of the support engineers to generate a support bundle on one of the Grid members. Please follow the instructions and generate the support bundle file.
  • 5 to 10 minutes
Task 1: Generating support bundles
Login to the GM user interface and download the support bundle for the member ibns2.techblue.net. You are asked to generate the support bundles with the following options:
  • Current Logs
  • Rotated Logs
  • Cached DNS Recursive Data
  • Cached Zone Data
Task 1 Solution: Generating support bundles
Generate a Support Bundle that contains Current Logs, Rotated Logs, Cached DNS Recursive Data and Cached Zone Data only for the ibns2.techblue.net device. Save the Support Bundle to the Downloads folder of the Linux jump-desktop.
  2. Navigate to Grid → Grid Manager → Members.
  3. Place a check mark in the box beside ibns2.techblue.net.
  4. From the Toolbar on the right, select Download → Support Bundle.
  5. In the Download Support Bundle window, check the boxes next to Current Logs, Rotated Logs, Cached DNS Recursive Data and Cached Zone Data then click OK
  6. Support Bundle can take a minute or two to generate. After generation is complete, your web browser may prompt you to save the file, or save it automatically to its default location.
The file name of the support bundle will always be supportBundle.tar.gz. We recommend you add the device name to the file to avoid future confusion when working with multiple support bundles. For example, this file from this lab can be renamed to: ibns2-supportBundle.tar.gz or 10.200.0.105-supportBundle.tar.gz.
