Starting DHCPv4 services in NIOS (2510)
You received a potential trouble report that DHCP services may not be running on DHCP servers (NIOS members) 10.100.0.105 and 10.200.0.105. Please verify that DHCPv4 services have started on Grid members. If not, please start them.
  • 5 to 10 minutes
  1. Starting DHCPv4 services
Task 1: Starting DHCPv4 services
Login to the GM user interface and verify that DHCPv4 services have been started on both 10.100.0.105 and 10.200.0.105. If not, please start the services.
Task 1 Solution: Starting DHCPv4 services
Services submenu under Grid → Grid Manager can give us the statuses of all services in the Grid.
  2. Navigate to Grid → Grid Manager → Services.
  3. Select the DHCP tile and verify DHCP service status for the members.
  4. Note the IP address 10.100.0.105 is configured to the member ibns1.techblue.net, and 10.200.0.105 is configured to the member ibns2.techblue.net.
  5. If the service is not started, place checkmarks in the boxes for both ibns1.techblue.net and ibns2.techblue.net.
  6. Click the Start button above the table and click Yes in the confirmation window to start DHCP service on selected members.
  7. Use the Refresh button to update the status display
