Assigning IPv6 addresses to NIOS Grid members (2511)
Your infrastructure team has enabled IPv6. You have been asked to configure one of the Grid members with the proper IPv6 information and verify its network connectivity. Please perform the necessary steps so the Grid member is reachable online via IPv6.
  • 15 to 20 minutes
  • Network information for the new IPv6 interface
  1. Assigning IPv6 addresses to members
  2. Verifying IPv6 connectivity
Task 1: Assigning IPv6 addresses to members
Login to the GM interface. Using the information provided in Table 2511-1 below, configure the member ibns2.techblue.net with an IPv6 address.
Table 2511-1
Address
Prefix Length
Gateway
fd10:200::105
64
fd10:200::1
Task 2: Verifying IPv6 connectivity
Verify the newly configured IPv6 address is reachable on the network.
Use the ping6 command on the Linux desktop.
Task 1 Solution: Assigning IPv6 addresses to members
Assign an IPv6 address to LAN1 on ibns2.techblue.net.
  2. Navigate to Grid → Grid Manager → Members.
  3. Click the menu/hamburger icon next to ibns2.techblue.net and choose Edit.
  4. Select the Network section.
  5. For Type of Network Connectivity, use the drop-down list to select IPv4 and IPv6.
  6. In the Ports and Addresses section, enter the information from Table 2511-1 in LAN1(IPV6) row.
  7. Save changes and click Yes to accept Warning message.
  8. Restart the DHCP Service by clicking the Restart button in the notification banner at the top of Grid Manager.
  9. Click Restart once more in the Restart Grid Services window.
Task 2 Solution: Verifying IPv6 connectivity
  1. Wait for ibns2.techblue.net to rejoin and show as Running in the Grid Manager.
  2. On the Jump Desktop, click on the Infoblox icon/Start menu, and launch Terminal Emulator.
  3. Enter the command ping6 -c4 fd10:200::105
