Starting DHCPv6 services in NIOS (2512)
One of the Grid members has recently been added an IPv6 interface. Please verify that the DHCPv6 service has started on that Grid member.
  • 5 to 10 minutes
  1. Verifying IPv6 interface on the member
  2. Starting the DHCPv6 service
Task 1: Verifying the IPv6 interface on the member
Login to the GM user interface and verify that the member ibns2.techblue.net has been properly configured with the IPv6 address fd10:200::105.
Task 2: Starting the DHCPv6 service
Start the DHCPv6 address on the member ibns2.techblue.net.
Task 1 Solution: Verifying the IPv6 interface on the member
Member settings of ibns2.techblue.net can help identify IPv6 configuration status.
  1. Navigate to Grid → Grid Manager → Members.
  2. Click the hamburger icon next to ibns2.techblue.net and choose Edit.
  3. Select the Network tab from the left.
  4. Check and make sure that IPv6 is available under Type of Network Connectivity.
  5. Scroll down further to the section Ports and Addresses and check the IPv6 address assigned to LAN1.
  6. Optionally, you can ping the IPv6 address from the jump-desktop to confirm reachability.
Task 2 Solution: Starting the DHCPv6 service
We can enable DHCP from the Services tab under Grid → Grid Manager
  2. Click the DHCP menu item.
  3. Check the box beside ibns2.techblue.net click the Edit button.
  4. Select the General tab from the left.
  5. Place a check mark in the box for IPv6 beside LAN1
  6. Click Save & Close to save changes
