Configuring global DHCPv4 options in NIOS (2513)
The DHCP team has decided that some DHCPv4 options should be set as global defaults. You have been given these options and values, please configure them in the Grid.
  • 15 to 25 minutes
  1. Configuring default domain name option.
  2. Configuring default DNS servers.
  3. Configuring default lease time.
  4. Configuring DHCP servers to be authoritative.
  5. Restarting the DHCPv4 services.
Task 1: Configuring the default domain name option
The default domain name (DHCPv4 option 15) for your organization is techblue.net. Please configure the NIOS Grid DHCP service with this as the global default.
Task 2: Configuring default DNS servers
The default DNS servers (DHCPv4 option 6) for your organization are 10.100.0.105 and 10.200.0.105. Please configure the NIOS Grid DHCP service with this as the global default.
Task 3: Configuring default lease time
The global default lease time has been determined to be 5 minutes. Please configure the NIOS Grid DHCP service with this as the global default.
Task 4: Configuring DHCP servers to be authoritative
Since the Infoblox Grid members are the authoritative DHCPv4 servers on the network, this means they are allowed to send DHCPNAK messages, informing clients to release leases they may have received from other, unauthorized, DHCP servers. Please make the configuration to set NIOS DHCP servers as authoritative.
Task 5: Restarting DHCPv4 services
Please restart services for all of these DHCP changes to take effect.
Restart services after you have completed all configurations, rather than restarting after each task. Your configuration is not complete after each task, restarting after each task or step will likely result in errors or the service not functioning properly.
Task 1 Solution: Configuring the default domain name option
Assigning Domain Name techblue.net as the default value for all DHCP members in the Grid.
  1. Navigate to Data Management → DHCP and select Grid DHCP Properties from the Toolbar on the right.
  2. Select the section or tab from the left IPv4 DHCP Options.
  3. In the Domain Name field, enter techblue.net.
Task 2 Solution: Configuring default DNS servers
Assigning 10.100.0.105 and 10.200.0.105 as default DNS servers for all DHCP members in the Grid
  2. Select the section for IPv4 DHCP Options.
  3. Click the Add button under the DNS Servers section
  4. Click directly in the field below IP Address and enter the IP address of the first DNS server: 10.100.0.105
  5. After entering the first DNS server, click the Add button again and enter the IP address of the second DNS server: 10.200.0.105
Task 3 Solution: Configuring default lease time
Configuring default lease time for all DHCP members in the Grid
  2. Select the General section
  3. Change value for Lease Time to 5
  4. Change the drop-down list to Minutes
  5. Click Save & Close to save changes
Task 4 Solution: Configuring DHCP servers to be authoritative
  3. Check the option for DHCP server is authoritative
  4. Click Save & Close to save changes
Task 5 Solution: Restarting DHCPv4 services
  1. Restart the DHCP Service by clicking the Restart button in the notification banner at the top of Grid Manager
  2. At the Restart Grid Services window, click Restart
