Creating DHCPv4 networks in NIOS (2514)
Your organization has expanded into a new office. As part of the network provisioning, you need to configure a network that is expected to provide DHCP service in the near future. Please provision a DHCPv4 network in NIOS.
  • 5 to 10 minutes
  • Knowledge of which Grid member(s) will serve DHCP for the network
  • DHCP configuration information such as default gateway
  1. Creating a DHCPv4 network.
  2. Restarting Grid services.
Task 1: Creating a DHCPv4 network
The IPv4 network that has been provisioned for this location is 172.31.111.0/24, with the default gateway 172.31.111.1. Shortly, more provisions will be done so DHCP service is provided by the member ibns1.techblue.net.
Task 2: Restarting Grid services
After saving changes, you should be prompted to restart services. If not, please manually restart services.
Task 1 Solution: Creating a DHCPv4 network
Create the DHCP Network 172.31.111.0/24 and set 172.31.111.1 as the default gateway for this network.
  1. Navigate to Data Management → DHCP → Networks → Networks
  2. Click the Add dropdown menu and select IPv4 Network
  3. Select the radio button for Add Network
  4. Click Next
  5. At Step 2 of 6 of the Wizard, leave the Netmask set to 24
  6. Next to Networks, click the Add button.
  7. Under the Network column, enter 172.31.111.0
  8. Click Next
  9. At Step 3 of 6, click the Add dropdown menu and select Add Infoblox Member
  10. Click on the link for ibns1.techblue.net from the Member Selector window
  11. Click Next after the Member info is populated
  12. At Step 4 of 7, click the Override button in the section for Routers (this will change the button color to black and the button will now say Inherit)
  13. Click the IP Address field in the Routers section
  14. Enter the IP address for the router on this network – 172.31.111.1
  15. Click Save & Close to save changes
Task 2 Solution: Restarting Grid services
Changes made to the DHCP configuration during Network creation only take effect after a service restart.
  1. Restart the DHCP Service by clicking the Restart button in the notification banner at the top of Grid Manager
  2. At the Restart Grid Services window, click Restart
Alternatively, we can also restart services from the Members menu.
  1. Navigate to Grid → Grid Manager → Members
  2. Place a checkmark in the box beside ibns1.techblue.net
  3. From the Toolbar on the right, click Restart Services
  4. Select the radio button to Force service restart
  5. Click Restart
