Creating DHCPv4 failover networks in NIOS (2516)
Your team has already created a DHCPv4 failover association. It is now time to provision a network to leverage this redundant service.
  • 10 to 15 minutes
  • Knowledge of which DHCPv4 failover associations to use
  • Basic DHCP configuration information such as the default gateway option
  • Network changes on DHCP relays such as routers to send DHCP messages to both Grid members
  1. Reading DHCPv4 failover association configuration
  2. Creating a DHCPv4 failover network.
  3. Restarting Grid services.
Task 1: Reading DHCPv4 failover association configuration
The DHCPv4 failover association to use for this configuration is "D1-D2". Please read its configuration in order to create a DHCPv4 network to use this redundant service.
Task 2: Creating a DHCPv4 failover network
The IPv4 network that needs the redundant DHCP service is 172.31.101.0/24, with the default gateway 172.31.101.1.
Task 3: Restarting Grid services
After saving changes, you should be prompted to restart services. If not, please manually restart services.
Task 1 Solution: Reading DHCPv4 failover association configuration
Understanding DHCP failover configuration is important for this task. While creating Network objects for DHCP failover ranges, both peers in the Failover Association should be assigned to the Network. Similarly, the MCLT value for DHCP failover association should also be verified to plan for service delivery.
  1. Navigate to Data Management → DHCP → Members → IPv4 DHCP Failover Associations
  2. Place a check next to D1-D2 and click Edit
  3. The General tab shows us the Members in a Failover Association
  4. The Advanced section (toggle advanced mode) of Failover Settings has the MCLT value
Task 2 Solution: Creating a DHCPv4 failover network
As stated above, while creating a Network meant for DHCP failover, the important step is to assign both the failover peers to the Network Object.
  1. Navigate to Data Management → DHCP → Networks → Networks
  2. Click the Add dropdown menu and select IPv4 Network
  3. Select the radio button for Add Network
  4. Click Next
  5. At Step 2 of 6, leave the Netmask set to 24
  6. Next to Networks, click the Add button
  7. Under the Network column, enter 172.31.101.0
  8. Click Next
  9. At Step 3 of 6, click the Add dropdown menu and select Add Infoblox Member, then click on the link for ibns1.techblue.net from the Member Selector window
  10. Repeat the above action once more to also assign ibns2.techblue.net to the Network
  11. Click Next after both the Members are populated
  12. At Step 4 of 7, click the Override button in the section for Routers (this will change the button color to black and the button will now say Inherit)
  13. Click the IP Address field in the Routers section
  14. Enter the IP address for the router on this network – 172.31.101.1
  15. Click Save & Close to save changes
Task 3 Solution: Restarting Grid services
Changes made to the DHCP configuration only take effect after the service restart.
  1. Restart the DHCP Service by clicking the Restart button in the notification banner at the top of Grid Manager
  2. At the Restart Grid Services window, click Restart
Alternatively, we can also restart services from the Members menu by navigating to Grid → Grid Manager → Members or Data Management → DHCP → Members
  1. From the Toolbar on the right, click Restart Services
  2. Select the radio button for Force restart services
  3. Click Restart
Note that the status of the failover association will display Failure until both networks and ranges have been assigned. This behavior is expected at the end of this lab.
