Overriding inherited DHCP options in NIOS (2517)
You realized that one of the Grid members serving DHCP for a branch office can be better managed by changing all of its default lease time to something different than the inherited value from the Grid. Please override this inherited configuration and verify it has taken effect.
  • 10 to 15 minutes
  1. Overriding the inherited option.
  2. Restarting Grid services.
  3. Reading the DHCP member configuration.
Task 1: Overriding inherited options
The default lease time for the Grid does not work for the member ibns2.techblue.net. Please make the necessary changes so all networks served by ibns2 have the default lease time of 900 seconds (15 minutes).
Task 2: Restarting Grid services
After saving changes, you should be prompted to restart services. If not, please manually restart services.
Task 3: Reading the DHCP member configuration
Please verify by examining the DHCP configuration file for ibns2.techblue.net.
Task 1 Solution: Overriding inherited options
  1. Navigate to Data Management → DHCP → Members
  2. Click the hamburger icon (=) next to ibns2 and choose Edit.
  3. In the General section, scroll down to find Lease Time
  4. Click Override and change the value to 15 minutes
  5. Click Save and Close to save changes
Task 2 Solution: Restarting Grid services
Changes made to the DHCP configuration only take effect after a service restart.
  1. Restart the DHCP Service by clicking the Restart button in the notification banner at the top of Grid Manager
  2. At the Restart Grid Services window, click Restart
Alternatively, we can also restart services from the Members menu.
  1. Navigate to Grid → Grid Manager → Members
  2. Place a check mark in the box beside ibns2.techblue.net
  3. From the Toolbar on the right, click Restart Services
  4. Select the radio button for Force service restart
  5. Click Restart
  1. Navigate to Data Management → DHCP → Members → Members
  2. Place a check mark in the box next to ibns2.techblue.net
  3. From the Toolbar on the right, click View DHCP Configuration
  4. Select IPv4(Disable pop up blocker)
  5. In the configuration file, locate the value of default-lease-time, it should be 900 seconds equivalent to 15mins.
