Creating a DHCPv4 option in NIOS (2518)
Your team has recently purchased some new network printers that require DHCPv4 option 150. Unfortunately, option 150 is not on the pre-defined DHCP options list. Please make the necessary configuration changes.
  • 10 to 15 minutes
  • DHCP option information to create (from vendor)
  1. Creating a DHCPv4 option.
  2. Assigning the new option to Grid.
  3. Restarting Grid services.
Task 1: Creating a DHCPv4 option
You have the following information from the printer vendor, on how to create the DHCPv4 option with code 150:
Table L325-1
Name
Code
Type
tftp-server
150
array of ip-addresses
Task 2: Assigning the new option to Grid
After creating the new DHCPv4 option, please assign this option at the DHCP Grid level, pointing all printers to the TFTP server 10.200.0.20.
Task 3: Restarting Grid services
After saving changes, you should be prompted to restart services. If not, please manually restart services.
Task 1 Solution: Creating a DHCPv4 option
DHCP Option 150(rfc5859) is an IANA-recognized option, which is not included in the default DHCP Option Space in NIOS. Therefore, we need to create a new IPv4 DHCP option according to IANA specifications. The Option Name, Option Code and Data type are all defined in the RFC.
  1. Navigate to Data Management → DHCP → Option Spaces
  2. Place a check mark in the box beside DHCP and click Edit
  3. Expand the DHCP (Option Space) window by clicking and dragging from the lower-right corner. This will make it easier to locate and add the necessary details in the following steps.
  4. In the DHCP(Option Space) window, click the Add button
  5. Scroll to the end of the list to find the blank entry
  6. For Name, enter tftp-servers
  7. For Code, enter 150
  8. For Type, use the list to select array of ip-address
  9. Click Save & Close
Task 2 Solution: Assigning the new option to Grid
Edit the DHCP Grid Properties and add 10.200.0.20 to the tftp-servers option for all IPv4 network
  1. Navigate to Data Management → DHCP → Networks
  2. From the Toolbar on the right, click Grid DHCP Properties
  3. Select the section labeled IPv4 DHCP Options
  4. Use the drop-down list for Custom DHCP Options to locate the entry for tftp-servers (150) (it will be at the very end of the list)
  5. Enter 10.200.0.20 for the value
  6. Click Save & Close
Task 3 Solution: Restarting Grid services
Changes made to the DHCP configuration only take effect after service restart.
  1. Restart the DHCP Service by clicking the Restart button in the notification banner at the top of Grid Manager
  2. At the Restart Grid Services window, click Restart
Alternatively, we can also restart services from the Members menu by navigating to Grid → Grid Manager → Members or Data Management → DHCP → Members
  1. From the Toolbar on the right, click Restart Services
  2. Select the radio button for Force restart services
  3. Click Restart
