Allowing and restricting DNS queries in NIOS (2519)
Your team decided to apply different security policies to two Grid members serving DNS. The first DNS member will accept queries from any client, the second member will only accept queries originating from internal address space. Please make the necessary configuration changes in the Grid.
  • 20 to 25 minutes
  • Which networks can perform DNS queries (connect on port 53)
Task 1: Allowing DNS queries on a member
The Grid member ibns1.techblue.net needs to accept DNS connections from any client. Please configure it as such.
Task 2: Restricting DNS queries on a member
The Grid member ibns2.techblue.net should only accept DNS connections from clients originating from the 10.100.0.0/16 network. Please configure it as such.
Task 3: Restarting Grid services
You should have been prompted to restart Grid services after making these changes. If not, please manually restart Grid services.
Task 1 Solution: Allowing DNS queries on a member
DNS Access Control can be applied at any level of the DNS hierarchy. In this lab, we will be applying it on members.
  1. Navigate to Data Management → DNS → Members
  2. Check the box next to ibns1.techblue.net and click Edit
  3. In the Member DNS Properties window, click on Queries tab
  4. Click Override in the Allow queries from section
  5. Choose Set of ACEs radio button and click Add  plus dropdown
  6. Select Any Address/Network and click Save & Close
Task 2 Solution: Restricting DNS queries on a member
For ibns2.techblue.net we will allow one network and deny all others
  2. Check the box next to ibns2.techblue.net and click Edit
  6. Select IPv4 Network
  7. Use the slider to set Netmask as /16
  8. In the Address box, type in 10.100.0.0 and click Add
  9. Click Save & Close
Task 3 Solution: Restarting Grid services
Changes made to DNS configuration will only take effect after a service restart on all members that were involved.
  1. Restart the Service when prompted by clicking Restart in the banner
  2. In the Restart Grid Services window, click Restart
Alternatively, we can also restart services from the Members menu by navigating to Grid → Grid Manager → Members or Data Management → DNS → Members
  1. From the Toolbar on the right, click Restart Services
  2. Select the radio button for Force restart services
  3. Click Restart
