Creating DNS name server groups in NIOS (2520)
You are consolidating types of name server mappings used for your internal authoritative zones. Some of the zones are mapped to members on the same Grid (hosted by the same Grid); some zones have the primaries on the Grid and send a copy to a secondary outside of the Grid; yet some other zones have the primary data hosted outside of the Grid, and some Grid members synchronize with the external primary to receive the zone data. Please create these 3 types of mappings as 3 different name server groups.
  • 20 to 30 minutes
Task 1: Creating an authoritative name server group with all Grid members
The most common authoritative zone mappings in your organization are that all zone data reside within the same Grid. Rather than specifying this mapping logic repeatedly at each zone, you can create a name server group (NS group), and (re)assign zones to use the group. Please create an authoritative name server group called Internal NSG. In the group, set ibns1.techblue.net as the Grid Primary and ibns2.techblue.net as the Grid Secondary.
Task 2: Creating an authoritative name server group with an external secondary
The development team wants a copy of your authoritative DNS zone data. The best way to set this up is via an automatic zone transfer, so whenever the zone data changes, the development team gets an updated copy. Please create an authoritative name server group called Dev NSG. In the group, set ibns1.techblue.net as the Grid Primary, ibns2.techblue.net as the Grid Secondary, and devns.techred.net (192.168.9.9) as the External Secondary.
Task 3: Creating an authoritative name server group with an external primary
The Microsoft team manages an authoritative zone that you would like a copy of. The best way is to set it up so that whenever the zone data changes on the Microsoft name server, an updated copy is sent to the Grid members. Please create an authoritative name server group called MS NSG. In the group, set dc01.techred.net (192.168.12.13) as the External Primary, and both ibns1.techblue.net and ibns2.techblue.net as the Grid Secondary.
Task 1 Solution: Creating an authoritative name server group with all Grid members
  1. Navigate to Data Management → DNS → Name Server Groups
  2. Click on the Add drop-down menu and select Authoritative
  3. For Name, enter Internal NSG
  4. Click the Add dropdown menu and select Grid Primary
  5. In the Add Grid Primary section, click Select to display the Member Selector
  6. In the Member Selector window click the entry for ibns1.techblue.net
  7. The selected device (ibns1.techblue.net) appears in the Add Grid Primary section
  8. Click the Add button to add ibns1.techblue.net as primary server
  9. Add the Grid Secondary device to the Name Server Group by clicking Add  plus → Grid Secondary
  10. In the section for Add Grid Secondary, click Select to open the Member Selector window
  11. Click on ibns2.techblue.net
  12. The device ibns2.techblue.net appears as the selected Grid Secondary
  13. The Name Servers table for this group now shows ibns1 as Grid Primary and ibns2 as Grid Secondary
  14. Click Save & Close
Task 2 Solution: Creating an authoritative name server group with an external secondary
  3. For Name, enter Dev NSG
  13. Add the External Secondary device to the Name Server Group by clicking Add  plus → External Secondary
  14. In the Add External Secondary section, provide Name devns.techred.net and for Address type in 192.168.9.9
  15. Click the Add button to add devns.techred.net as External Secondary server
  16. The Name Servers table for this group now shows ibns1 as Grid Primary, ibns2 as Grid Secondary and devns.techred.net as External Secondary
  17. Click Save & Close
Task 3 Solution: Creating an authoritative name server group with an external primary
  3. For Name, enter MS NSG
  4. Click the Add dropdown menu and select External Primary
  5. In the Add External Primary section, provide Name dc01.techred.net and for Address type in 192.168.12.13
  6. Click the Add button to add dc01.techred.net as the primary server
  7. Add the Grid Secondary device to the Name Server Group by clicking Add  plus → Grid Secondary
  8. In the section for Add Grid Secondary, click Select to open the Member Selector window
  9. Click on ibns1.techblue.net
  10. The device ibns1.techblue.net appears as the selected Grid Secondary
  11. Add the other Grid Secondary device to the Name Server Group by clicking Add  plus → Grid Secondary
  12. In the section for Add Grid Secondary, click Select to open the Member Selector window
  13. Click on ibns2.techblue.net
  14. The device ibns2.techblue.net appears as the selected Grid Secondary
  15. The Name Servers table for this group now shows dc01.techred.net as External Primary, ibns1 and ibns2 as Grid Secondary devices.
  16. Click Save & Close
