Configuring Named ACLs in NIOS (2521)
You are configuring access to DNS service and realized that you are entering the same subnet information repeatedly. This information can be captured in a reusable Named ACL, then applied to each Grid object, to keep security policies simpler and more consistent. Please create a Named ACL object with the subnet information.
  • 15 to 20 minutes
Task 1: Creating a named ACL
You are repeatedly entering the same subnet information listed in Table 2521-1 to various objects to define access policy. Please create a Named ACL with these values, and give it the name Company Internal Subnets to make future configuration work easier.
Table 2521-1
Type
Value
Operation
IPv4 Network
172.31.0.0/16
Allow
IPv4 Network
10.100.0.0/24
Allow
IPv4 Network
10.200.0.0/24
Allow
IPv4 Address
127.0.0.1
Allow
IPv6 Network
fdac:31::/32
Allow
IPv6 Network
fd10:100::/32
Allow
IPv6 Network
fd10:200::/32
Allow
IPv6 Address
::1
Allow
Task 2: Applying the Named ACL to existing objects
Now that you have a Named ACL, you may update existing objects to use it, making maintaining the correct access policy easier. Please update both DNS members ibns1 and ibns2 to only allow recursive queries from Company Internal Subnets.
Task 1 Solution: Creating a named ACL
  1. Navigate to Administration → Named ACLs
  2. Click Add
  3. For Name, enter Company Internal Subnets
  4. Click Next
  5. At Step 2 of 3, click the Add dropdown menu and select IPv4 Network from the list
  6. For Address, enter 172.31.0.0/16
  7. Use the slider to set the Netmask to 16 (255.255.0.0)
  8. Default Permission is set to Allow, leave it at that
  9. Click Add
  10. Repeat the above steps to add all subnets from table 2521-1
  11. Click Save & Close
  12. The Named ACL table now includes the Company Internal Subnets entry
Task 2 Solution: Applying the Named ACL to existing objects
Edit the Member DNS Grid Properties for both ibns1 and ibns2 and allow Recursive Queries from the Company Internal Subnets ACL
  1. Navigate to Data Management → DNS →Members
  2. Place a check next to ibns1.techblue.net and click the Edit button
  3. Select the Queries tab
  4. Scroll down to find the section for Recursion
  5. Click the Override button
  6. Place a check mark in the box for Allow recursion
  7. Select the radio button for Named ACL
  8. Click the Select Named ACL button
  9. If Company Internal Subnets is the only Named ACL you have created, it will be populated automatically, otherwise from the Named ACL Selector screen, click the Company Internal Subnets link
  10. Click Save & Close
  11. Repeat the above steps for ibns2.techblue.net
  12. Restart the DNS service by clicking Restart on the banner at the top of the Grid Manager window
  13. At the Restart Grid Services window, click Restart
