Creating authoritative primary zones in NIOS (2522)
Your company has started a major new division, and a new domain name needs to be created. The zone will be managed and hosted on the NIOS Grid. Please create this authoritative primary zone.
  • 5 to 15 minutes
  1. Creating an authoritative primary zone.
Task 1: Creating an authoritative primary zone
Please create the zone techblue.net. Configure it to use the Grid primary ibns1.techblue.net, and its Grid secondary ibns2.techblue.net.
Task 1 Solution: Creating an authoritative primary zone
Create a new zone called techblue.net. Assign the Name Servers ibns1 and ibns2 to this zone as primary and secondary servers respectively.
  1. Navigate to Data Management → DNS → Zones
  2. Click the Add dropdown menu and select Authoritative Zone
  3. Leave the radio button set to Add an authoritative forward-mapping zone
  4. Click Next
  5. For Name, enter techblue.net
  6. For Comment, enter Parent zone for TechBlue
  7. Leave the remaining settings unchanged and click Next
  8. Select the radio button for Use this set of name servers
  9. Click the Add dropdown menu and select Grid Primary
  10. In the Add Grid Primary section, click Select to display the Member Selector
  11. In the Member Selector window click the entry for ibns1.techblue.net
  12. The selected device (ibns1.techblue.net) appears in the Add Grid Primary section
  13. Click the Add button to add ibns1.techblue.net as primary server
  14. Add the Grid Secondary device to the Name Server Group by clicking Add  plus → Grid Secondary
  15. In the section for Add Grid Secondary, click Select to open the Member Selector window
  16. Click on ibns2.techblue.net
  17. The device ibns2.techblue.net appears as the selected Grid Secondary
  18. The table for now shows ibns1 as Grid Primary and ibns2 as Grid Secondary
  19. Click Save & Close
  20. The Zones table now contains a new entry for the techblue.net Authoritative zone
