Creating authoritative secondary zones in NIOS (2523)
Your training department is operating its own DNS server, with the zone training.techblue.net. You would like to receive a read-only copy of the zone data on the authoritative primary zone. Please configure this authoritative secondary zone in NIOS.
  • 10 to 15 minutes
  1. Creating an authoritative secondary zone.
Task 1: Creating an authoritative secondary zone
The training department's DNS server is imai.techblue.io. Use the following command on the jump-desktop VM to identify the current IP address of imai.techblue.io: dig +short imai.techblue.io. Please configure an authoritative secondary zone for training.techblue.net to receive data from imai.techblue.io. The Grid secondary members are ibns1.techblue.net and ibns2.techblue.net.
Task 1 Solution: Creating an authoritative secondary zone
Create the training.techblue.net Authoritative (Secondary) zone
  1. Lookup the IP address of imai.techblue.io (You can use the dig +short imai.techblue.io. command in a terminal on your jump-desktop)
  2. From Grid Master UI , navigate to Data Management → DNS → Zones
  3. Click the Add dropdown menu and select Authoritative Zone
  4. Leave the radio button set to Add an authoritative forward-mapping zone
  5. Click Next
  6. For Name, enter training.techblue.net
  7. Leave the remaining settings unchanged and click Next
  8. Select the radio button to Use this set of name servers
  9. Click the Add drop-down menu and select External Primary
  10. For Name Server Name, enter imai.techblue.io
  11. For the Name Server Address, enter the IP address that you looked up for imai.techblue.io
  12. Check Use TSIG
  13. Select the radio button next to Key Name if it is not already selected
  14. Populate the Key name, Key algorithm, and Key Data from the file in the folder Shared Drive named tsig_xfer_nios.txt. This is on your jump-desktop VM. (full path is /mnt/shared/tsig_xfer_sha256.txt)
  15. Click Add
  16. Click the Add drop-down menu again, and select Grid Secondary
  17. Click on the Select button, and select ibns1.techblue.net from the name server list
  18. Click Add to add it to the list of zone name servers
  19. Repeat the above steps to add ibns2.techblue.net as a Grid Secondary
  20. Click Save & Close
  21. The Zones window now displays the new training.techblue.net authoritative zone (you may need to click Toggle Flat View)
  22. Click on the Restart button in the notification banner
  23. Click Restart in the Restart Grid Services window
