Creating authoritative DNS subzones in NIOS (2524)
The sales department within your organization needs to manage its own namespace, sales.techblue.net. As the administrator, you want to allow operators to manage entries in this space for you. Please set up the necessary configurations on the NIOS Grid.
  • 15 to 20 minutes
  1. Creating an authoritative subzone.
  2. Configuring the subzone permissions to be read-write by a specific group.
Task 1: Creating an authoritative subzone
Create the authoritative subzone sales.techblue.net. The sales department is not using its own DNS server(s). Please re-use the same name servers as the parent zone, techblue.net.
Task 2: Configuring subzone permissions
Allow the group operators to have read-write access to the subzone sales.techblue.net.
Task 1 Solution: Creating an authoritative subzone
  1. Navigate to Data Management → DNS → Zones
  2. Click the Add dropdown menu and select Authoritative Zone
  3. Leave the radio button set to Add an authoritative forward-mapping zone
  4. Click Next
  5. For Name, enter sales.techblue.net
  6. Leave the remaining settings unchanged and click Next
  7. Select the radio button for Use this set of name servers
  8. Click the Add dropdown menu and select Grid Primary
  9. In the Add Grid Primary section, click Select to display the Member Selector
  10. In the Member Selector window click the entry for ibns1.techblue.net
  11. The selected device ibns1.techblue.net appears in the Add Grid Primary section
  12. Click the Add button to add ibns1.techblue.net as primary server
  13. Add a Grid Secondary device by clicking Add plus → Grid Secondary
  14. In the section for Add Grid Secondary, click Select to open the Member Selector window
  15. Click on ibns2.techblue.net
  16. The device ibns2.techblue.net appears as the selected Grid Secondary
  17. Click the Add button to add ibns2.techblue.net as a Grid Secondary server
  18. The table shows ibns1 as Grid Primary and ibns2 as Grid Secondary
  19. Click Save & Close
The subzones tab under techblue.net now contains a new entry for the sales.techblue.net authoritative zone
Task 2 Solution: Configuring subzone permissions
The easiest way to edit the subzone's permissions is to edit the zone settings:
  1. Inside techblue.net, go to Subzones and edit sales.techblue.net
  2. Navigate to the Permissions tab
  3. Click + and select the operators group
  4. Once the operators group name populates, edit the Permissions field using the drop-down box, set the permissions to ‘Read/Write’.
  5. Click Save and Close
  6. Now, users in the operators group will be allowed read-write access to manipulate the sales.techblue.net subzone configurations and records.
