Creating IPv4 authoritative reverse-mapping zones in NIOS (2527)
Your team has recently been given the responsibility to manage the name entries in the network 172.16.0.0/16. Please make the appropriate configurations in the Grid.
  • 15 to 20 minutes
  • (Optional) Administrative IPAM access to the Grid
  1. Creating an IPv4 authoritative reverse-mapping zone.
  2. (Bonus) Creating a corresponding IPv4 network in IPAM.
Task 1: Creating an IPv4 authoritative reverse-mapping zone
Create 172.16.0.0/16 as an authoritative reverse-mapping zone, served by the name server group Internal NSG.
Bonus Task: Creating both reverse-mapping zone and network
If you are using the Grid for both DNS and IPAM, you should create a corresponding network in IPAM that matches the reverse-mapping zone in DNS. There is a way to create both the authoritative IPv4 reverse-mapping zone and the IPv4 network if they happen to be a certain size (such as /16 or /24). Create an IPAM network object for 192.168.0.0/16 and check the option during creation to automatically create the IPv4 reverse-mapping zone.
Task 1 Solution: Creating an IPv4 authoritative reverse-mapping zone
  1. Navigate to Data Management → DNS → Zones
  2. Click the Add dropdown menu and select Authoritative Zone
  3. At Step 1 of 6, select the radio button for Add an authoritative IPv4 reverse-mapping zone
  4. Click Next
  5. At Step 2 of 6, select the radio button for IPv4 Network
  6. For the network, enter 172.16.0.0
  7. Change the Netmask to 16
  8. For Comment, enter TechBlue Branch Networks
  9. Click Next
  10. At Step 3 of 6, select the radio button for Use this name server group
  11. Select Name Server Group Internal NSG
  12. Click Save & Close
  13. The Zones table now displays the new 16.172.in-addr.arpa authoritative zone
