Configuring DNS anycast in NIOS (2536)
Infrastructure team has approved BGP-based anycast in the corporate network. Configure Infoblox DNS members, so multiple DNS members can be in an anycast group for increased DNS availability and redundancy.
  • 25 to 30 minutes
Task 1: Configuring members for IPv4 DNS anycast
Configure members ibns1 and ibns2 with loopback address and BGP configuration for IPv4 using the following values:
  • Loopback Interface Address: 10.24.7.53
  • BGP Config:
    • ASN: 65400
    • Neighbor Router:
      • ibns1 → 10.100.0.1
      • ibns2 → 10.200.0.1
    • Remote ASN: 65247
Task 2: Configuring DNS services on members to listen on additional IPv4 addresses
Reconfigure the DNS services on members ibns1 and ibns2 to listen on the new anycast address 10.24.7.53.
Task 3: Verifying anycast address is reachable
Verify the anycast address 10.24.7.53 is reachable on the network. You may use the ping command on the jump-desktop.
Task 4: Verifying DNS service on anycast address
Use the dig utility on the jump-desktop to verify that the IPv4 anycast address is providing DNS services.
Task 5: Verifying redundancy on anycast address
Disable the DNS service on member ibns1 to simulate a systems failure. Then query the IPv4 anycast address to resolve a name. If anycast is working as expected, the same IPv4 address will still respond even when a member if offline.
You may use this dig query for both Tasks 4 and 5.
dig @10.24.7.53 test.techblue.net.
Task 1 Solution : Configuring members for IPv4 DNS anycast
Repeat the following steps for both members ibns1 and ibns2.
  1. Navigate to Grid → Grid Manager → Members.
  2. Highlight the member (ibns1.techblue.net or ibns2.techblue.net) and choose Edit.
  3. Select the section for Anycast
  4. Under the Anycast Interfaces section, click the Add dropdown menu and select IPv4 Address
  5. In the Address field, enter 10.24.7.53, and check the checkbox for BGP
  6. Don’t save yet, scroll down to the BGP Configuration section.
  7. For the ASN, enter 65400.
  8. In the BGP Neighbor Configuration section below, click the Add button.
  9. In the field for Neighbor Router, enter the appropriate router IP for the member being configured:
  10. In the Remote ASN field, enter 65247.
  11. Click the Add button to add this entry.
  12. Click Save & Close
  13. A Warning message appears about changing network settings. Read and click Yes.
  14. This member will be restarting. Repeat the same steps on the other member using the corresponding Neighbor router IP.
Task 2 Solution: Configuring DNS services on members to listen on additional IPv4 addresses
Perform the following steps on to reconfigure the DNS services on members ibns1 and ibns2.
  1. Navigate to Grid → Grid Manager → Services → DNS.
  2. Place a check mark in the box next to the member (ibns1.techblue.net or ibns2.techblue.net) and click the Edit button.
  3. The Member DNS Properties dialog window appears.
  4. Under the General tab (displayed by default), find the section Listen on these additional IP addresses. Click Add.
  5. A new entry appears with a drop-down menu for Address selection. Choose 10.24.7.53 (Anycast).
  6. Click Save & Close
  7. Repeat the same steps on the other member.
  8. Restart service after both members have been configured.
  9. Wait until all members are back to the Running (green) state before starting the next task.
Task 3 Solution: Verifying anycast address is reachable
  1. Wait until both ibns1 and ibns2 have finished restarting.
  2. On the jump-desktop, open a Terminal window. Enter the command ping 10.24.7.53.
When dealing with DNS anycast, it is important to test each component separately. Remember that the DNS service is built on top of the anycast service. Test that anycast is working with ping. Then test DNS with dig.
Task 4 Solution : Verifying DNS service on anycast address
  1. On the jump-desktop, open a Terminal window. Enter the command dig @10.24.7.53 test1.techblue.net.
  2. What name we look up is not important, nor is the response. What is important here is that we see a DNS response from this IP address.
Starting a contiguous ping to the anycast address
  1. Before disabling the DNS service, start a contiguous ping on jump-desktop to the anycast address 10.24.7.53 from a Terminal window.
  2. Keep this Terminal window open as you disable the DNS service. You can observe that the anycast address is available throughout the process.
Disabling the DNS service
  1. In the GM web interface, navigate to Data Management → DNS → Members.
  2. Place a check in the box beside ibns1.techblue.net and click the Stop button in the Toolbar.
  3. Click Yes to confirm the action.
  4. Use the Refresh button in the bottom left of the window to update the display.
  5. Wait for the Service Status for ibns1 to change to Not Running.
Verifying anycast functionality
  1. Return to the Terminal window that has the contiguous ping command running.
  2. You should see no packet loss to the IP address 10.24.7.53, and the address is still reachable even after one of the DNS members have been disabled.
Verifying DNS functionality
Repeat the dig lookup command from Task 4. You should receive the same results.
  2. What name we look up is not important, nor is the response. What is important here is that we still see a DNS response from this IP address, although one of the DNS members is now disabled.
