Configuring Dynamic DNS (DDNS) in NIOS (2540)
On your DHCP-enabled network, there are many corporate users who you need to reach by name. However, their IP addresses may change from day to day. To reduce the amount of administrative overhead, your team has decided to enable dynamic DNS (DDNS) on the subnet, so that when users receive a DHCP lease on this network, their DNS entries in the zone ddns.techblue.net are automatically updated. Please make the necessary configuration in NIOS.
  • 15 to 20 minutes
  • Administrative DNS and DHCP access to the Grid
  1. Update the DHCP option for domain name.
  2. Enable Dynamic DNS (DDNS).
  3. Verify the new configuration is working.
Task 1: Updating the DHCP option for domain name
Update DHCP Option 15(Domain Name) for the network 172.31.101.0/24 to the value ddns.techblue.net
Task 2: Enabling Dynamic DNS (DDNS)
Enable Dynamic DNS at the network level for 172.31.101.0/24
Task 3: Verifying the new configuration is working
Verify that DDNS updates are working as expected
Task 1 Solution: Updating the DHCP option for domain name
  1. Navigate to Data Management→DHCP→Networks→Networks
  2. Place a check next to the 172.31.101.0/24 network and click Edit
  3. Select the section for IPv4 DHCP Options
  4. In the Domain Name field, click Override and enter ddns.techblue.net
  5. Click Save & Close
Task 2 Solution: Enabling Dynamic DNS (DDNS)
  2. Place a check next to the 172.31.101.0/24 network and click edit
  3. Click Toggle Advanced Mode and Select the section for IPv4 DDNS
  4. Click the Override button next to DDNS Updates, and place a check in the box for Enable DDNS Updates
  5. Click Save & Close and Restart Services
Task 3 Solution: Verifying the new configuration is working
  1. Switch to testing-linux VM
  2. Open terminal and type in sudo set-network-disable(for sudo password use infoblox)
  3. To clear any existing leases, type in sudo clear-dhcp-leases
  4. Get a new DHCP lease by typing in sudo set-network-dhcp
  5. Switch back to the jump-desktop and Navigate to Data Management→DNS→Zones
  6. Open techblue.net and navigate to Sub Zones tab
  7. Open the ddns.techblue.net subzone and check for testing-linux A record
  8. Alternatively, we can check the syslog messages for ibns1(primary for ddns.techblue.net) by the named daemon, adding forward mapping for testing-linux.ddns.techblue.net
