Configuring DHCPv4 MAC Filters in NIOS (2563)
During routine network monitoring, you noticed that the testing-windows device has been repeatedly requesting and receiving DHCP leases. However, this device is no longer authorized to access the network. To resolve this, you will implement a MAC address filter to block this device from obtaining further IP addresses.
You will begin by identifying the testing-windows device’s MAC address, configure a MAC address filter in NIOS to block it, and then verify that the device can no longer acquire a DHCP lease from the range.
  • 15 to 20 minutes
Task 1: Request a DHCP Address
  • Use Command Prompt on the testing-windows VM to request a DHCP address using ipconfig /renew command.
  • Verify that the client has obtained an IP address using the command: ipconfig
Task 2: Find the MAC Address of the Client
  • From the Grid Manager UI locate the lease details of the testing-windows client and note down its MAC address.
Task 3: Define and Apply a MAC Address Filter to the DHCP Range
  • Create a MAC address filter named Restricted_Device for the noted MAC address.
  • Apply the MAC filter to the DHCP range 172.31.101.75-172.31.101.85.
Task 4: Confirm the Client Does Not Receive a DHCP Lease
  • Use Command Prompt on the testing-windows VM to attempt to renew the IP address using the command: ipconfig /renew
  • Verify that the client no longer receives a lease.
Task 1 Solution: Request a DHCP Address
To complete this task, follow these steps to request a DHCP address on the testing-Windows VM:
  1. Log in to the VM testing-windows.
  2. Click the Command Prompt icon from the taskbar to open it.
  3. Type the command: ipconfig /renew
  4. After the process completes, verify the new IP address by typing: ipconfig.
Note: The IP address shown in the screenshot may differ from the IP address that the DHCP server provides to the Windows client during this lab.
Task 2 Solution: Find the MAC Address of the Client
To find the MAC address of the client, use the following steps:
  1. Switch to jump-desktop and open a browser to access Grid Manager UI at 10.100.0.100.
  2. Navigate to Data Management > DHCP > Leases > Current Leases
  3. Find the lease assigned to the testing-windows client in the table.
  4. Note down the MAC address displayed in the table for use in the next task.
Task 3 Solution: Define and Apply a MAC Address Filter to the DHCP Range
While still in the Grid Manager UI, follow these steps:
  1. Navigate to Data Management > DHCP > Filters.
  2. Click plus icon to select IPv4 MAC Address Filter.
  3. In the Add IPv4 MAC Filter Wizard:
    • For Name, enter: Restricted_Device.
    • Click Save & Close.
  4. From the filter list, click the newly created Restricted_Device filter.
  5. Add the noted MAC address to the filter:
    • Click plus icon to open the IPv4 MAC Address Filter Item Wizard .
    • For MAC address, enter: 00:50:56:00:9f:8e.
  6. Navigate to Data Management > DHCP > Networks > 172.31.101.0/24.
  7. Select the range 172.31.101.75-172.31.101.85 and click Edit.
  8. Toggle Advanced Mode if it's not already enabled.
  9. Go to Filters > Basic and in the CLASS FILTER LIST, click the plus icon.
  10. Select the Restricted_Device MAC filter and change the action to Deny Lease from the drop-down menu.
  11. Click Save & Close.
  12. Restart services when prompted.
Task 4 Solution: Confirm the Client Does Not Receive a DHCP Lease
To test the effectiveness of the MAC filter, follow these steps:
  1. Switch back to the testing-windows VM.
  2. In Command Prompt, release the current IP address by using the following command: ipconfig /release
  3. Then, attempt to obtain a new IP address by using: ipconfig /renew
Expected Output
After executing the ipconfig /release command, the current IP address will be released. When you attempt to obtain a new IP address with the ipconfig /renew command, the client will not receive an IP address because the MAC Address filter prevents the DHCP server from assigning a lease.
The ipconfig /renew command will eventually time out, displaying the following message:
