Configuring Source-Based Topology Ruleset (2568)
Your organization is implementing DNS Traffic Control (DTC) to direct user traffic based on where DNS queries originate. Instead of returning the same response to all clients, queries from specific source subnets should be answered from designated server pools. In this lab, you will configure DTC to map source networks to the appropriate pools of servers, enabling finer control of traffic distribution.
  • 30 minutes
Task 1: Configure Source-Based Topology Ruleset
Create a topology ruleset named Source Rule with the following IP-to-pool mappings to direct DNS responses based on the source IP.
Table 2568-1
Source Subnet
DTC Pool/Server
Order
10.0.0.0/8
Pool A
1
192.168.0.0/16
Pool B
2
172.16.0.0/12
Pool B
3
Task 2: Set Up the Load-Balanced Domain Name (LBDN)
Configure a Load-Balanced Domain Name (LBDN) stan.dtc.techblue.net that uses the Source Rule topology ruleset created in Task 2.
Task 3: Test the Source-Based Topology Ruleset
Use the Test LBDN tool to verify that the LBDN is functioning as expected.
Task 1 Solution: Configure Source-Based Topology Ruleset
To configure a source-based topology ruleset, proceed with the following steps:
  1. Navigate to Data Management → DNS → Traffic Control.
  2. From the toolbar panel on the right, click Manage Topology Ruleset
  3. Click Add (+) to create a new ruleset.
  4. In the Ruleset Wizard, Enter the following details:
    1. Name: Source Rule
    2. Destination Type: Pool
    3. Comment: Source IP-based rules
  5. In the Rules section,
    1. click the Add (+) dropdown menu and select Subnet Rule.
    2. In the Add Subnet Rule window Set Source Subnet to 10.0.0.0/8
    3. For Destination/Response, select DTC Pool/Server and choose Pool A.
    4. Click Add to save this rule.
  6. Repeat these steps to add additional subnet rules as specified in Table 2568-1.
  7. After adding all the rules, set the Default destination if none of the above rules match option to Pool A.
  8. Click Save & Close to save the ruleset configuration.
  9. Click Close on the Topology Manager window.
Task 2 Solution: Set Up the Load-Balanced Domain Name (LBDN)
Create an LBDN that uses the Source Rule topology by following these instructions:
  2. Click the Add (+) dropdown menu and select LBDN to open the DTC LBDN Wizard.
  3. In Step 1 of the wizard, enter the following details:
    • Display Name: Subnet Test
    • Patterns: Click + to add a new pattern, enter stan.dtc.techblue.net
    • Load Balancing Method: Topology
    • Topology Ruleset: Source Rule (created in the previous Task)
  4. Click Next to proceed.
  5. In Step 2, verify that the following record types are selected:
    • A
    • CNAME
    • AAAA
  6. Click Add (+) and select the Associated Zone dtc.techblue.net, then click Next.
  7. In Step 3, click Add (+) to add Pool A and Pool B.
  8. Click Save & Close to complete the LBDN setup.
  9. When prompted, select Restart Services to apply the changes.
Task 3 Solution: Test the Source-Based Topology Ruleset
Verify the functionality of the Source-Based Topology Ruleset with these steps:
  2. Select the LBDN Subnet Test.
  3. From the Toolbar, click Test LBDN to open the Test DTC LBDN (Web) tool.
  4. Enter the following test details:
    • Query Source: 10.10.10.10 (or any address from 10.0.0.0/8)
    • Query Name: stan.dtc.techblue.net
    • Member: ibns1.techblue.net
    • Record Type: A
  5. Click Start to send a test query and observe the response.
  6. Verify that the response IP matches Pool A's IP addresses (10.100.0.210 or 10.100.0.220), as configured.
  7. Repeat the test with different Query Source address. Table 2568-2 shows the expected answer for eaceh source address.
Table 2568-2
Query Source
Expected Pool Destination
10.10.10.10
Pool A (10.100.0.210 or 10.100.0.220)
192.168.1.1
Pool B (10.200.0.210 or 10.200.0.220)
172.16.2.2
128.171.3.3
