Configuring Dynamic DNS in BloxOne DDI (2579)
Cloud Services Portal (CSP) is now Infoblox Portal
In early September, Cloud Services Portal (CSP) became Infoblox Portal with a new look-and-feel, and a new URL (https://portal.infoblox.com). As a result of this change, the layout and organization of several menus have been updated.
Unfortunately, this means that our video courseware and lab guides no longer match the new user interface. However, we are currently in the process of updating them, and they should be ready soon.
In the meantime, we have some resources to help you navigate the new interface:
We have created a mapping of the previous menu locations and their new breadcrumb location.
Additionally, you can find a walkthrough video of the new User Interface on Launchpad.
We apologize for any inconvenience this may cause and kindly ask for your patience as we work through this transition.
Several clients have been complaining that DNS entries for their machines are old and out of date. Some are completely missing. IT has decided to enable DDNS from the DHCP perspective so that for every new lease, the DHCP server will issue DDNS requests.
Estimated Completion Time
15 to 20 minutes
Administrative access to the CSP
Lab 2801: Deploying BloxOne Hosts
Lab 2570: Configuring DHCP Services in BloxOne DDI
Lab 2571: Creating DHCP Networks in BloxOne DDI
Lab 2573: Enabling and Configuring DNS Services
Lab 2574: Creating a Primary Zone in BloxOne DDI
Create a new DNS forward mapping zone called ddns.techblue.net
Allow DDNS Updates in DHCP and DNS
Enable DDNS on the 172.31.101.0/24 network and configure the DDNS Domain Name value
Test DDNS
Examine the lease
Task 1: Create a new DNS forward mapping zone called ddns.techblue.net
We need to create a new DNS forward mapping zone ddns.techblue.net in the default DNS view. This will be the authoritative zone for this domain. We want to use both of our BloxOne DNS Service Instances to host this zone, Techblue DNS service 1 and Techblue DNS service 2. We'll also need to set an email address for the SOA RNAME field to our admin's email address, admin@techblue.net.
Task 2: Allow DDNS Updates in DHCP
We will need to check that DDNS Updates are enabled in the Global DHCP Configuration and set the default domain name ddns.techblue.net. We also want to make sure the updates are going to ddns.techblue.net, that lease renewals will update DNS record(s) and when there is a conflict, we want DNS to be updated for the DHCID records as well.
Task 3: Test DDNS
We've enabled DDNS and set the default domain to ddns.techblue.net but now we should test to make sure it works. Verify from testing-linux. We can also take a look at the records created in the ddns.techblue.net zone.
Task 4: Examine the lease
Now that the DHCP server can update DNS with records for the DHCP clients it serves, we can take a look at the lease information, which includes DNS record information.
Task 1 Solution: Create a new DNS forward mapping zone called ddns.techblue.net
With the CSP browser main menu, navigate to Manage β DNS
Select the Zones tab
Click on the default DNS View to go inside the view
Click the Create button, and from the drop-down select Primary Zone
Enter the zone Name:
ddns.techblue.netFor Description, enter a description for this zone like
Zone for DDNSExpand the Authoritative DNS Servers section
Under DNS Authoritative Servers, click the arrow next to both of your DNS service instances to move them to the list of Authoritative DNS Servers
Expand the Zone Setting Defaults section
Set the Email Address (For SOA RNAME Field) to: admin@techblue.net (you will need to click the Override toggle to override the default setting)
Click Save & Close
Task 2 Solution: Allow DDNS Updates in DHCP
Navigate to Manage β IPAM/DHCP
Click on Global DHCP Configuration
Scroll down to the DDNS section and expand it.
Check the box for Enable Dynamic DNS Service
For Default Dynamic DNS Domain name, enterddns.techblue.net.Under DDNS ZONES click Add and select Internal Zone
Select the ddns zone by selecting default β techblue.net β ddns and click Add to the right
Select the checkbox for Update DNS record(s) on DHCP lease renewal
Scroll down to the Conflict Resolution section and check the radio button for Update DNS and add or update DHCID records
Click Save & Close
Task 3 Solution: Test DDNS
Letβs test this configuration from our test client
On the testing-linux Virtual Machine, open a Terminal window
Set the IP address as a fixed address with the command
sudo set-network-static-bloxoneto allow a route to the DNS server.We are going to bounce the network interface ens160 on this machine to force a new lease to be retrieved, which will accompany a DDNS update. Use the following commands:
Disable the network interface with
sudo set-network-disable(for sudo password use infoblox)To clear any existing leases, type in
sudo clear-dhcp-leasesObtain a new DHCP lease using the command
sudo set-network-dhcpNow check that a lease is present with
sudo show-dhcp-lease
You may see that there is now an option entry:
option host-name "testing-linux.ddns.techblue.net"You can also test DNS resolution for the A record from here with
dig @10.100.0.110 testing-linux.ddns.techblue.net A
Now, weβll check the Resource Records in our DNS Zone
With the CSP browser window, navigate to Manage β DNS
Click on the techblue.net zone to go inside of the zone
We can see our entries for the zone we created, ddns.techblue.net, with the description we set and BloxOne DDI as the DNS Provider. Click on ddns on the list in the techblue.net zone to see the records in the zone.
We can see the A record for testing-linux.ddns.techblue.net with a RECORD SOURCE of Dynamic and the DHCID record for the DHCP server identification.
Task 4 Solution: Examine the lease
Navigate to the IP address range for our testing-linux VM by clicking through Techblue Network β 172.31.0.0/16 β 172.31.101.0/24 β 172.31.101.100-172.31.101.199
Select the entry for testing-linux, we can expand the Lease Information panel to the right (in the information panel).
Notice that the Hostname of the lease entry for our testing-linux VM is testing-linux.ddns.techblue.net. This was generated by the system using DDNS.
