Configuring GeoIP-Based Topology Ruleset (2583)
Your organization is implementing DNS Traffic Control (DTC) to direct user traffic based on geographic location. Instead of relying on source subnets or metadata, DNS queries should be answered using GeoIP information derived from the client’s location. In general, traffic originating from North America, the United Kingdom, and even Antarctica should be directed to Pool A, while all other regions should default to Pool B.
In this lab, you will configure DTC to map geographic locations to the appropriate server pools, enabling location-based traffic distribution.
  • 30 minutes
Task 1: Update the GeoIP Database
Update the GeoIP database using the file GeoLite2-City.mmdb from the SharedDrive/nios-imports folder.
Task 2: Configure a GeoIP-Based Topology Ruleset
Create a topology ruleset named External GeoIP Rule with the following geographic IP-to-pool mappings to tailor DNS responses based on request origin.
Table 2583-1
Continent
Country
Subdivision
City
Destination
North America
ANY
ANY
ANY
Pool A
ANY
United Kingdom
ANY
ANY
Pool A
Antarctica
ANY
ANY
ANY
Pool A
Note: When the ANY is trailing a value, it is not required to be manually added
Task 3: Set Up the Load-Balanced Domain Name (LBDN)
Configure a Load-Balanced Domain Name (LBDN) with the pattern cartman.dtc.techblue.net that uses the External GeoIP Rule topology ruleset created in Task 2.
Task 4: Test the GeoIP-Based Topology Ruleset
Use the Test LBDN tool to verify that the LBDN for cartman.dtctechblue.net is functioning as expected.
For each test, use the following common details:
  • Query Name: cartman.dtc.techblue.net
  • Member: ibns1.techblue.net
  • Record Type: A
Use the Query Source IPs from Table 2583-2 below. For each IP, initiate the test and observe whether the response is from the expected pool.
Table 2583-2
Query Source
Location
199.185.13.10
Antarctica
45.45.45.45
Canada
13.248.0.10
Japan
41.76.88.0
Tanzania
83.140.109.99
Sweden
128.171.1.1
Hawaii
190.98.0.10
Suriname
Task 1 Solution: Update the GeoIP Database
Follow these steps to update the GeoIP database:
  1. Navigate to Data Management → DNS → Traffic Control.
  2. From the Toolbar panel, click Topology Database dropdown menu and select Import GeoIP Database.
  3. In the Import dialog, navigate to Shared Drive/nios-imports and select the file GeoLite2-City.mmdb.
  4. Click Upload and wait for the import to complete.
  5. After the upload, reopen the Topology Database dropdown menu.
  6. Select Current Version to confirm the update date reflects the Build Date of 2023-07-08.
Task 2 Solution: Configure a GeoIP-Based Topology Ruleset
To configure a GeoIP-based topology ruleset, proceed with the following steps:
  2. From the toolbar panel on the right, click Manage Topology Ruleset
  3. Click Add (+) to create a new ruleset.
  4. In the Ruleset Wizard, Enter the following details:
    • Name: External GeoIP Rule
    • Destination Type: Pool
    • Comment: GeoIP-based ruleset
  5. In the Rules section,
    1. click the Add (+) dropdown menu and select Geography Rule.
    2. In the Add Geography Rule section Set Continent equals North America
    3. Set Country as Any
    4. Set Subdivision as Any
    5. Set City as Any
    6. For Destination/Response, select DTC Pool/Server and choose Pool A.
    7. Click Add to save this rule.
  6. Repeat these steps to add additional Geography rules as specified in Table 2583-1.
  7. After adding all the rules, set the Default destination if none of the above rules match option to Pool B.
  8. Click Save & Close to save the ruleset configuration.
  9. Click Close on the Topology Manager window.
Task 3 Solution: Set Up the Load-Balanced Domain Name (LBDN)
To set up an LBDN using the GeoIP Rule topology ruleset, follow these steps:
  2. Click the Add dropdown menu and select LBDN to open the DTC LBDN Wizard.
  3. In Step 1 of the wizard, enter the following details:
    • Display Name: GeoIP Test
    • Patterns: Click + to add a new pattern, then enter cartman.dtc.techbelue.net.
    • Load Balancing Method: Topology
    • Topology Ruleset: External GeoIP Rule (created in the previous task)
  4. Click Next to proceed.
  5. In Step 2, verify that the following record types are selected:
    • A
    • CNAME
    • AAAA
  6. Click Add (+) and select the Associated Zone dtc.techblue.net, then click Next.
  7. In Step 3, click Add (+) to add Pool A and Pool B.
  8. Click Save & Close to complete the LBDN setup.
  9. When prompted, select Restart Services to apply the changes.
Task 4 Solution: Test the GeoIP-Based Topology Ruleset
Verify the functionality of the GeoIP-based topology ruleset on the LBDN with these instructions.
  2. Select the LBDN EA Test.
  3. From the Toolbar, click Test LBDN to open the Test DTC LBDN tool.
  4. Enter the following test details:
    • Record Type: A
  5. For each Query Source address from Table 2583-2, enter the IP address and click Start to initiate the test. Observe the result and verify that it matches the expected response from the concerned pool.
  6. Review the results for each query. Confirm that traffic is directed to the correct pool based on the topology rules configured in Task 2. Table 2583-2 shows the expected results for each query source address.
Table 2583-2
Query Source
Expected Result
199.185.13.10
Pool A (10.100.0.210 or 10.100.0.220)
45.45.45.45
13.248.0.10
Pool B (10.200.0.210 or 10.200.0.220)
41.76.88.0
83.140.109.99
128.171.1.1
190.98.0.10
