Limiting Recursion with Named ACLs (2605)
Your team decided to apply different security policies to your Grid members serving DNS. members will only accept queries originating from internal address space using named ACLs. Please make the necessary configuration changes in the Grid.
  • 20 to 25 minutes
  • Which networks can perform DNS queries (connect on port 53)
Task 1: Named ACL and Limit Recursion
  • In this task, you will update the Grid DNS settings to protect against two attacks targeted at recursive servers.
    1. Login to the Grid Master IBGM (10.100.0.100):
      1. Navigate to Administration → Named ACLs
      2. Create a new ACL with the name Trusted Networks
      3. Add the two networks 10.100.0.0/24 and 10.200.0.0/24  and the host Jump-Desktop(10.35.22.10) to the list, then Save & Close.
      4. Navigate to Data Managment → DNS
      5. On the Toolbar click on Grid DNS Properties
      6. Select Queries and under the Allow queries from section choose Named ACL
      7. Click Select Nmaed ACL and choose Trusted Networks, then Save & Close
      8. Restart services when prompted.
Task 2: Verifying Recursion Limitations
  • In this task, you will verify that the configuration done in the previous step did work.
    1. On the Jump-Desktop(10.35.22.10):
      1. Open a terminal window
      2. Execute a dig command querying IBNS1 (10.100.0.105) for www.example.com
         dig @10.100.0.105 www.example.com.
        1. What was the response? why?
    2. On the Testing-Linux:
      2. Execute the command sudo set-network-static-nios and use 'infoblox' as the password if prompted.
      3. Execute a dig command querying IBNS1 (10.100.0.105) for www.example.com
    7. Click Select Named ACL and choose Trusted Networks, then Save & Close
  • Detailed Analysis:
On the Jump-Desktop(10.35.22.10) our dig query will be responded to normally with the NOERROR response code and an A record, this is because we added the host to the Named ACL we used allowing this host to use the Grid's recursion services, ash shown the figure below:
However, once we move over to Testing-Linux which is after executing the command sudo set-network-static-nios has the IP address outside of the scope of our created Named ACL Trusted Networks, as we can see below:
So when we execute the same dig command on Testing-Linux the response is different, we get the REFUSED response with the warning message recursion requested but not available. Which is as we know is due to the ACL blocking us from using the Grid DNS recursion services.
This can also be verified by the syslog message for ibns1, shown below:
