Skip to main content
Skip table of contents
Utilizing BloxOne Country-Based Response Policy Zones (RPZ) (2805)
Cloud Services Portal (CSP) is now Infoblox Portal
In early September, Cloud Services Portal (CSP) became Infoblox Portal with a new look-and-feel, and a new URL (https://portal.infoblox.com). As a result of this change, the layout and organization of several menus have been updated.
Unfortunately, this means that our video courseware and lab guides no longer match the new user interface. However, we are currently in the process of updating them, and they should be ready soon.
In the meantime, we have some resources to help you navigate the new interface:
We apologize for any inconvenience this may cause and kindly ask for your patience as we work through this transition.
You're tasked to deploy BloxOne country-based RPZs to block traffic from certain countries, this is to keep your organization in line with new regulatory demands, you will add Russia, North Korea and China to your RPZ and test out the RPZ functions as intended.
  • 30-50 mins
Course Reference
  • 2104: Creating Custom and Country Based RPZ with BloxOne TIDE
  • Administrative access to the CSP
  • Lab 2804: Managing BloxOne Endpoints
  • Task 1: Create a Country based RPZ
  • Task 2: Add the country-based RPZ to the security policy
  • Task 3: Verify Country-Based RPZ work
  • Create a new country based RPZ and name it blocked-countries
    • Add Russia, China and North-Korea to the RPZ
  • Add the county based RPZ into the techblue Policy security policy
  • Verify that the feed has been populated on CSP
    • Using your testing-windows machine browse dzen.ru to verfiy the RPZ is working.
Please wait for 20-30 minutes for the records to be synchronized, the feed will display no records immediately after creation.
Task 1 solution: Create a Country based RPZ
  1. Switch to jump-Desktop, in your CSP browser, and navigate to Manage > TIDE Data > Country-based RPZ.
  2. Click the Add Country Based RPZ button and set the feed name to blocked-countries.
  3. Add the countries Russia, China, and North Korea to the Include list by clicking the arrow next to each of them, then click Save & Close.
Task 2 solution: Add the country-based RPZ to the security policy
  1. In your CSP browser, navigate to Policies > Security Policies, check the policy we have been working with in previous labs Techblue-Policy, and click Edit.
  2. Click on the policy rules section, click on Add Rule, and choose Feeds and Threat Insight (this should be the fifth rule on the list).
  3. Set the name to be your country-based RPZ feed name blocked-countries and with the action Block-Default Redirect, then click finish and Save & Close.
Task 3 solution: Verify Country-Based RPZ work
  1. In your CSP browser, navigate to Policies > On-Prem DNS Firewall and click the Feed Configuration Values button, your created RPZ should be at the bottom of the list
  2. Switch to the testing-windows machine, surf dzen.ru using your web browser, and you should be redirected to a page like this:
JavaScript errors detected
Please note, these errors can depend on your browser setup.
If this problem persists, please contact our support.
