Audit Event Investigation in NIOS (3507)
The zone younglings.sw stopped working at around 11:50 AM UTC on 7th June 2023. Investigate the issue and find details about this incident.
15 to 20 minutes
For all tasks in this lab, please use the support bundle placed on the desktop of the jump-desktop. It is named 3507-supportBundle.tar.gz.
Task 1: Find details about the incident from the support bundle logs
  1. Who made the change and what changed to cause the issue?
  2. What access method (GUI/API) was used to make the change?
  3. Which user created the user account that made the change?
Solution
    Answer: Anakin user deleted the Authoritative zone younglings.sw
    audit.log
    2023-06-07 11:46:43.365Z [anakin]: Deleted AuthZone younglings.sw DnsView=default exclude_subobj=True
    Answer: GUI
    audit.log
    2023-06-07 11:45:01.325Z [anakin]: Login_Allowed - - to=AdminConnector ip=10.35.22.10 auth=LOCAL group=Not\040Master apparently_via=GUI
    Answer: Obiwan
    audit.log
    2022-09-02 11:18:24.032Z [[Obiwan]: Created AdminMember anakin: Set extensible_attributes=[],auth_type="LOCAL",ca_certificate_issuer=NULL,comment="",disabled=False,email="",groups=[AdminGroup:.Not\040Master],name="anakin",password="******",ssh_keys=[],use_ssh_keys=False
