Performing traffic captures in NIOS (3508)
You are assisting in troubleshooting an issue that impacts a Grid member. As part of the troubleshooting, you need to perform packet capture on the member. Please perform packet (traffic) capture and download the capture file(s).
  • 15 to 20 minutes
  1. Performing traffic capture
  2. Downloading the capture file
  3. Opening the capture file in Wireshark
Task 1: Performing traffic capture
Login to the GM user interface and start a traffic capture session on the member ibns1. Let the capture run for 30 seconds.
Task 2: Downloading the capture file
When the capture is complete, download the capture from the member ibns1.
Task 3: Opening the capture file in Wireshark
On the jump-desktop, open the capture file using the Wireshark analyzer software.
Task 1 Solution: Performing traffic capture
Login to the GM web interface and generate a 30 second traffic capture on LAN1 of ibns1.techblue.net
  1. Navigate to Grid → Grid Manager → Members
  2. From the Toolbar on the right, scroll down and click Traffic Capture
  3. Click Add plus and select ibns1.techblue.net from the Member Selector pop-up window
  4. Select HA from the drop-down list for Interface
  5. Enter 30 for the Seconds to Run field
  6. Allow the capture to run until the 30 seconds elapses and the Download button becomes available
Task 2 Solution: Downloading the capture file
Save the file to the Downloads folder on the Linux workstation
  1. Place a check mark in the box beside ibns1.techblue.net
  2. Click Download and choose download destination
  3. The downloaded file will consist of the name of the member for which the capture was performed, and the timestamp
Task 3 Solution: Opening the capture file in Wireshark
Open the capture file in Wireshark
  1. Extract the tcpdumpLog.tar.gz file by right clicking on the file and choosing Extract Here
  2. Extracted filename will be traffic.cap
  3. Double click the file to open in Wireshark
