Troubleshooting REFUSED DNS message in NIOS (3516)
User reports that she tried to look up www.techblue.net but received a REFUSED error message. The dig output is attached below. Please diagnose the issue.
$ dig @10.100.0.105 www.techblu.net.
; <<>> DiG 9.18.12-0ubuntu0.22.04.2-Ubuntu <<>> @10.100.0.105 www.techblu.net.
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 64700
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; WARNING: recursion requested but not available
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1220
; COOKIE: fe4cc82f2914d71a9443360464c4319580b9f7e79182b7f5 (good)
;; QUESTION SECTION:
;www.techblu.net.		IN	A
;; Query time: 4 msec
;; SERVER: 10.100.0.105#53(10.100.0.105) (UDP)
;; WHEN: Fri Jul 28 21:22:29 UTC 2023
;; MSG SIZE  rcvd: 72
  • 15 to 20 minutes
Task 1: Troubleshooting REFUSED message
Investigate resolution issue with the help of dig tool and resolve the issue after finding root cause.
Examine the output sent by the user closely.
Task 1 Solution: Troubleshooting REFUSED message
Look closely at the first line of the output sent by the user. The FQDN is misspelled as techblu.net (missing the letter e).
Detailed Analysis
  • Line 1: We query the name server 10.100.0.105 directly.
  • Line 7: The status code REFUSED indicates that the server 10.100.0.105 refused service (details on the next 2 lines).
  • Line 8: We see only qr and rd flags, missing ra (recursion available) and aa (authoritative answer). This means the server is unable to provide the answer locally (not authoritative), and unable to ask others (cannot perform recursion).
  • Line 9: This line provides the clear error message that the server 10.100.0.105 is unable to perform recursion.
With all of this information combined, this is what happened: the DNS server 10.100.0.105 is not configured to allow recursion (indicated by lines 8 and 9). We can check the Grid and see that the server ibns1 (10.100.0.105) does have an authoritative zone configured, but it is spelled differently than the one the user queried. The one configured on the Grid is spelled techblue.net, while the user queried for techblu.net (without e).
