Troubleshooting External DNS Resolution in NIOS (3517)
There is an external-facing domain name training.infoblox.com that is intended for the Internet. However, internal users are reporting that when they query ibns1 (10.100.0.105) or ibns2 (10.200.0.105) this name fails to resolve. Identify any issues and correct them.
  • 15 to 20 minutes
Task 1: Troubleshooting internal resolvers
Investigate and resolve name resolution issues for training.infoblox.com domain from our internal resolvers ibns1 and ibns2.
Task 1 Solution: Troubleshooting internal resolvers
When using the command dig to query ibns1 (10.100.0.105), we get this output:
dig @10.100.0.105 training.infoblox.com
; <<>> DiG 9.18.12-0ubuntu0.22.04.1-Ubuntu <<>> @10.100.0.105 training.infoblox.com
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: REFUSED, id: 41800
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; WARNING: recursion requested but not available
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1220
; COOKIE: 85a66043fb06626ee9dd2eb964905dc76e8ec5242c06683e (good)
;; QUESTION SECTION:
;training.infoblox.com.        IN    A
;; Query time: 4 msec
;; SERVER: 10.100.0.105#53(10.100.0.105) (UDP)
;; WHEN: Mon Jun 19 13:53:11 UTC 2023
;; MSG SIZE  rcvd: 78
The REFUSED code in line 7 and the warning in line 9 indicate that recursion is not enabled on this server (10.100.0.105). Repeating this
Enabling recursion on the members
The recommended method is to allow recursion on each member individually. Enabling recursion at the Grid level to turn it on for every Grid member is not recommended.
To enable recursion on a member:
  1. Navigate to Data Management → DNS → Members.
  2. Select and Edit the member (ibns1 or ibns2).
  3. In Member DNS Properties, select the Queries tab.
  4. Scroll down to check the Allow recursion configuration.
  5. Click Save & Close, restart service when prompted.
You may run the same dig command again, it should now produce the following output:
training@jump-desktop:~ $ dig @10.100.0.105 training.infoblox.com.
; <<>> DiG 9.18.12-0ubuntu0.22.04.2-Ubuntu <<>> @10.100.0.105 training.infoblox.com.
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 1872
;; flags: qr rd ra; QUERY: 1, ANSWER: 4, AUTHORITY: 0, ADDITIONAL: 1
; COOKIE: e037c5c66896c2fa4423f20464c3c345bcdbdfc7336c7650 (good)
;; ANSWER SECTION:
training.infoblox.com.	3600	IN	A	151.101.130.253
training.infoblox.com.	3600	IN	A	151.101.66.253
training.infoblox.com.	3600	IN	A	151.101.2.253
training.infoblox.com.	3600	IN	A	151.101.194.253
;; Query time: 431 msec
;; WHEN: Fri Jul 28 13:31:49 UTC 2023
;; MSG SIZE  rcvd: 142
