Troubleshooting DNS views in NIOS (3523)
A new DNS view Internal has been added to the Grid, with a zone named techred.net. The expected behavior is that all internal clients from the 10.100.x.x address space will now be able to resolve these 2 names:
  • www.techred.net → 10.10.10.55
  • ldap.techred.net → 10.10.10.66
However, when users attempt to look up these two names, they are seeing these results:
$ dig @10.100.0.105 www.techred.net.
; <<>> DiG 9.11.12 <<>> @10.100.0.105 www.techred.net.
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 32318
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;; ANSWER SECTION:
www.techred.net.   2371  IN    CNAME techred.net.
techred.net.       3596  IN    A     186.202.151.17
;; Query time: 13 msec
;; SERVER: 10.100.0.105#53(10.100.0.105)
;; WHEN: Thu Aug 19 20:10:55 UTC 2021
;; MSG SIZE  rcvd: 102
$ dig @10.100.0.105 ldap.techred.net. A
; <<>> DiG 9.11.12 <<>> @10.100.0.105 ldap.techred.net. A
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 9066
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; AUTHORITY SECTION:
techred.net.       3600  IN    SOA   ns1.locaweb.com.br. postmaster.locaweb.com.br. 2013110701 3600 600 1209600 3600
;; Query time: 136 msec
;; WHEN: Thu Aug 19 20:12:10 UTC 2021
;; MSG SIZE  rcvd: 138
Please identify the root cause and provide a fix so names are resolved as expected.
  • 15 to 20 minutes
Task 1: Troubleshooting DNS views
Use lookup tools and logs to identify why clients are being served answers from the incorrect DNS view. Correct the view configuration and verify proper name resolution
Task 1 Solution: Troubleshooting DNS views
Study the 2 dig outputs carefully, specifically, looking at the header flags, you should notice the absence of the AA flag, and the presence of the RA flag:
;; ANSWER SECTION:
This indicates that these answers are non-authoritative, the Infoblox member ibns1 (10.100.0.105) had to query another name server to get these answers. This is not how query is supposed to flow, as we have a zone named techred.net configured in the view Internal, so this indicates our queries are not captured by the view, which mostly likely means the view ordering or match-client statements are misconfigured.
Navigate to Data Management → DNS → Members, edit member ibns1, toggle the Advanced Mode → DNS Views, scroll down to the section Order of DNS Views, and you will see that the view default is placed at the top, and the view Internal is placed at the bottom (shown below).
 Change the ordering such that the Internal view is above the default view.
Repeat the above configuration steps on the member ibns2.techbelue.net to re-order its DNS views.
Re-run the dig queries, they should show different results now, check for the AA flag in each of the answers, indicating these are authoritative responses, that Infoblox members did not query any other name servers for the answer.
