Troubleshoot DHCP issue: no free leases in NIOS (3526)
Your colleagues have created a new subnet to provide DHCP service. However, you received reports that clients are unable to receive leases on this subnet. A copy of the DHCP logs were provided for your analysis. Please investigate and provide a fix so clients receive DHCP services on this subnet.
  • 15 to 20 minutes
Task 1: Analyzing the provided syslog messages
Study the syslog messages given below and predict the possible configuration issues that can cause this scenario.
Syslog
20080:2023-07-06T18:58:13+00:00 daemon ibns1.techblue.net dhcpd[27923]: err DHCPDISCOVER from 00:50:56:00:1a:2b via 172.31.101.1 TransID 42fab6ac: network 172.31.101.0/24: no free leases
20081:2023-07-06T18:58:28+00:00 daemon ibns1.techblue.net dhcpd[27923]: err DHCPDISCOVER from 00:50:56:00:1a:2b via 172.31.101.1 TransID 42fab6ac: network 172.31.101.0/24: no free leases
20082:2023-07-06T18:58:36+00:00 daemon ibns1.techblue.net dhcpd[27923]: err DHCPDISCOVER from 00:50:56:00:1a:2b via 172.31.101.1 TransID 42fab6ac: network 172.31.101.0/24: no free leases
20083:2023-07-06T18:58:38+00:00 daemon ibns1.techblue.net dhcpd[27923]: err DHCPDISCOVER from 00:50:56:00:2d:3c via 172.31.101.1 TransID 7a1cac01: network 172.31.101.0/24: no free leases
20084:2023-07-06T18:58:41+00:00 daemon ibns1.techblue.net dhcpd[27923]: err DHCPDISCOVER from 00:50:56:00:2d:3c via 172.31.101.1 TransID 7a1cac01: network 172.31.101.0/24: no free leases
20085:2023-07-06T18:58:44+00:00 daemon ibns1.techblue.net dhcpd[27923]: err DHCPDISCOVER from 00:50:56:00:2d:3c via 172.31.101.1 TransID 7a1cac01: network 172.31.101.0/24: no free leases
20086:2023-07-06T18:58:48+00:00 daemon ibns1.techblue.net dhcpd[27923]: err DHCPDISCOVER from 00:50:56:00:2d:3c via 172.31.101.1 TransID 7a1cac01: network 172.31.101.0/24: no free leases
20087:2023-07-06T18:58:54+00:00 daemon ibns1.techblue.net dhcpd[27923]: err DHCPDISCOVER from 00:50:56:00:2d:3c via 172.31.101.1 TransID 7a1cac01: network 172.31.101.0/24: no free leases
20088:2023-07-06T18:59:08+00:00 daemon ibns1.techblue.net dhcpd[27923]: err DHCPDISCOVER from 00:50:56:00:2d:3c via 172.31.101.1 TransID 7a1cac01: network 172.31.101.0/24: no free leases
You can also log on to the VM testing-linux and use the commands sudo set-network-dhcp and sudo clear-dhcp-leases to test the DHCP behavior.
Task 2: Updating DHCP configuration
Correct any faulty configuration and make necessary changes to resolve the issue.
Task 1 Solution: Analyzing the provided syslog messages
Syslog
The syslog messages do indicate that the server has run out of leases. To get more information, it is necessary to look at the DHCP configuration.
Since the syslog messages were from ibns1.techblue.net, we should check its configuration:
  1. Navigate to Data Management→DHCP→Members→Members.
  2. Check the box next to the member ibns1.techblue.net
  3. From the Toolbar, select View DHCP Configuration → IPv4.
  4. This shows us the DHCP configuration file. You can scroll down and notice this section that indicates there are no DHCP ranges or other objects configured for this network:
    subnet 172.31.101.0 netmask 255.255.255.0 {
  5. We can investigate further by check the configuration in Grid by navigating to Data Management → DHCP and click the network 172.31.101.0/24. We can see that it does have a range, but it is configured as a IPv4 Reserved Range, thus not available for DHCP service.
Task 2 Solution: Updating DHCP configuration
To correct the configuration, we can change this range from Reserved to being assigned to at least one Grid member.
  1. Login to NIOS GM web interface, navigate to Data Management→DHCP→Networks→Networks.
  2. Open the 172.31.101.0/24 network.
  3. Check the box next to the range object and click Edit.
  4. In the dialog window, switch to the Member Assignment tab on the left. Change Served by to Grid Member ibns1.techblue.net.
  5. Click Save & Close and restart services when prompted.
You may now test receiving a lease from the VM testing-linux.
